For AI agents: the complete documentation index is available at https://docs.ovhcloud.com/en/llms.txt, the full documentation bundle is available at https://docs.ovhcloud.com/en/llms-full.txt, and this page is available as Markdown at https://docs.ovhcloud.com/en/guides/manage-and-operate/kms/okms-certificate-management.md.
Skip to content
Manage your OKMS access certificate
View as Markdown
Manage your access certificate for your Data Security products
The purpose of this guide is to show you the steps to follow to configure and manage the OKMS access certificate for your Data Security products.
OVHcloud Control Panel Access
  • Direct link:
  • Navigation path: Identity, Security & Operations > Key Management Service > Select your OKMS domain
OKMS access certificate description
To communicate with your OKMS domain, you need an access certificate. This is one of three OKMS authentication methods; certificates are required for KMIP and recommended when mTLS client authentication is needed. For REST API usage, a Personal Access Token or service account is usually simpler to set up.
An access certificate is only valid for the domain for which it was generated.
Only the certificate creation with a CSR is covered by the PCI-DSS certification.
Create an access certificate from the KMS
OVHcloud API
It's possible to create this certificate from the dedicated entry of the KMS.
In the Access certificates tab, click on Generate an access certificate.
Create a certificate
The first part of the form allows you to precise its validity duration, choose signature algorithm, and providing or not your Certificate Signing Request (CSR) in case you have your own private key.
Without providing a private key
If you do not provide a CSR, OVHcloud will generate the certificate and a private key as well.
With a CSR
If you own your own private key, it's possible to use it with a CSR.
The second part of the form allows you to specify the OVHcloud identities associated with the certificate used to calculate access rights via the OVHcloud IAM.
It is possible to add the root identity to the certificate so as not to be constrained by the OVHcloud IAM.
You then need to download the private key of the certificate.
Danger
The private key will no longer be accessible at a later stage. If you lose it, you will need to regenerate a certificate.
The privateKeyPEM field needs to be edited so that all instances of \n are replaced by carriage returns.
Finally it's possible to download the public key of the certificate from the dashboard.
Using the OVHcloud KMS with your data.
Was this page helpful?
