title: "Manage your OKMS access certificate"
description: "Manage your access certificate for your Data Security products"
url: https://docs.ovhcloud.com/en/guides/manage-and-operate/kms/okms-certificate-management
lang: en
lastUpdated: 2025-10-01
# Manage your OKMS access certificate
## Objective
The purpose of this guide is to show you the steps to follow to configure and manage the OKMS access certificate for your Data Security products.
## Requirements
- An [OVHcloud customer account](/en/guides/account-and-service-management/account-information/ovhcloud-account-creation.md).
- An [OVHcloud KMS ordered](/en/guides/manage-and-operate/kms/quick-start.md)
### OVHcloud Control Panel Access
- **Direct link:** <ManagerLink to="/#/dedicated/security/kms">Key Management Service</ManagerLink>
- **Navigation path:** <code className="action">Identity, Security & Operations</code> > <code className="action">Key Management Service</code> > Select your OKMS domain
## Instructions
### OKMS access certificate description
To communicate with your OKMS domain, you will need to create an access certificate.
Access certificate to an OKMS domain are used for the **Key Management Service (KMS)**. This will be used for any interaction with the domain, either to create encryption keys or to carry out operations with them.
An access certificate is only valid for the domain for which it was generated.
:::warning
Only the certificate creation with a CSR is covered by the PCI-DSS certification.
### Create an access certificate from the KMS
#### From the Control Panel
It's possible to create this certificate from the dedicated entry of the KMS.
In the `Access certificates
` tab, click on `Generate an access certificate
![Create a certificate](/images/manage-and-operate/kms/okms-certificate-management/create_certificat_01.png)
The first part of the form allows you to precise its validity duration, choose signature algorithm, and providing or not your Certificate Signing Request (CSR) in case you have your own private key.
##### **Without providing a private key:**
If you do not provide a CSR, OVHcloud will generate the certificate and a private key as well.
![Create a certificate](/images/manage-and-operate/kms/okms-certificate-management/create_certificat_02.png)
##### **With a CSR:**
If you own your own private key, it's possible to use it with a CSR.
![Create a certificate](/images/manage-and-operate/kms/okms-certificate-management/create_certificat_03.png)
The second part of the form allows you to specify the [OVHcloud identities](/en/guides/manage-and-operate/iam/identities-management.md) associated with the certificate used to calculate access rights via the [OVHcloud IAM](/en/guides/account-and-service-management/account-information/iam-policy-ui.md).
It is possible to add the `root` identity to the certificate so as not to be constrained by the OVHcloud IAM.
![Create a certificate](/images/manage-and-operate/kms/okms-certificate-management/create_certificat_04.png)
You then need to download the private key of the certificate.
:::warning
The private key will no longer be accessible at a later stage. If you lose it, you will need to regenerate a certificate.
:::warning
The **privateKeyPEM** field needs to be edited so that all instances of `\n` are replaced by carriage returns.
![Create a certificate](/images/manage-and-operate/kms/okms-certificate-management/create_certificat_05.png)
Finally it's possible to download the public key of the certificate from the dashboard.
![Create a certificate](/images/manage-and-operate/kms/okms-certificate-management/create_certificat_06.png)
#### From the API
You can generate this certificate by letting OVHcloud generate the private key, or by providing your Certificate Signing Request (CSR) in case you have your own private key.
##### **Without providing a private key**
If you do not provide a CSR, OVHcloud will generate the access certificate along with a private key.
You can generate a certificate via the following API call:
🇪🇺EU▾
[POST/okms/resource/{okmsId}/credential](https://eu.api.ovh.com/console/?section=/okms&branch=v2#post-/okms/resource/-okmsId-/credential)
The following information is required:
- **name**: the name of the certificate
- **identityURNs**: list of OVHcloud identities in URN format that will be provided to the IAM for calculating access rights
- **description**: certificate description (optional)
- **certificateType**: certificate signature algorithm (ECDSA or RSA) - ECDSA by default (optional)
- **validity**: certificate validity duration in days - 365 days by default (optional)
**Example of certificate creation with root account:**
```json
  "description": "My root access credential",
  "identityURNs": [
    "urn:v1:eu:identity:account:xx1111-ovh"
  "name": "root",
  "validity": 30
**Example of certificate creation with local user:**
```json
  "description": "My access credential",
  "identityURNs": [
    "urn:v1:eu:identity:user:xx1111-ovh/john.smith",
    "urn:v1:eu:identity:group:xx1111-ovh/my_group"
  "name": "John Smith",
  "validity": 30
The API then returns the certificate creation status:
```json
  "id": "f18b5e0d-75b8-40a3-9b0e-XXXXXX",
  "identityURNs": [
  "certificateType": "ECDSA",
  "status": "CREATING",
  "fromCSR": false,
  "privateKeyPEM": "-----BEGIN EC PRIVATE KEY-----\nMHcCAQEEIDOfWuMVQxl5quoURzThF4zTI9YYTmylSaPjneLBwP+2oAoGCCqGSM49\nAwEHoUQDQgAERd1eMw0YdAD+E9oSymGc4bCL1mfJl0EZwoM2ya/uKFFVFnGMnckg\nXXXXXXXXXXXXXXX==\n-----END EC PRIVATE KEY-----\n",
  "createdAt": "2024-04-04T12:26:28.856619+02:00",
  "expiredAt": "2025-04-04T12:26:28.856616+02:00"
Copy the value of the **privateKeyPEM** field to a **domain.key** file
:::danger
:::warning
Then copy the certificate ID and access its details via the API:
🇪🇺EU▾
[GET/okms/resource/{okmsId}/credential/{credentialId}](https://eu.api.ovh.com/console/?section=/okms&branch=v2#get-/okms/resource/-okmsId-/credential/-credentialId-)
The API returns the certificate in PEM:
```json
  "identityURNs": [
  "status": "READY",
  "fromCSR": false,
  "certificatePEM": "-----BEGIN CERTIFICATE-----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\nDlyP5HhrWyFB9BICIDl5wtUWgCmo6TjOqXXXXXXXXXXXXXX\n-----END CERTIFICATE-----",
Copy the value of the **certificatePEM** field to a **client.cert** file.
:::warning
The **certificatePEM** field needs to be edited so that all instances of `\n` are replaced by carriage returns.
##### **With a CSR**
If you have your own private key, it is possible to use it by providing a CSR.
🇪🇺EU▾
- **csr**: the content of the CSR
:::warning
The CSR must be in JSON format. The CSR file must be edited so that there are no carriage returns; instead, `\n` will have to be inserted where the line breaks were previously (see the example below). You can also use third-party tools available online to adjust content into the correct JSON format.
**Example of certificate creation:**
```json
  "csr": "-----BEGIN CERTIFICATE REQUEST-----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\n97Ob1alpHPoZ7mWiEXXXXXXXXXXXXX\n-----END CERTIFICATE REQUEST-----",
  "identityURNs": [
  "validity": 30
```json
  "identityURNs": [
  "fromCSR": true,
Copy the ID of the certificate and access its details via the following API call:
🇪🇺EU▾
```json
  "identityURNs": [
  "status": "READY",
  "fromCSR": true,
## Go further
[Using the OVHcloud KMS with your data](/en/guides/manage-and-operate/kms/kms-usage.md).
