For AI agents: the complete documentation index is available at https://docs.ovhcloud.com/es/llms.txt, the full documentation bundle is available at https://docs.ovhcloud.com/es/llms-full.txt, and this page is available as Markdown at https://docs.ovhcloud.com/es/guides/network/load-balancer/use-api-reference.md.
Ir al contenido
Load Balancer API Quick Reference
Ver como Markdown
Quick description of the different API functions used to manage the Load Balancer
List of API functions
This section briefly describes the main functions of the API for the OVHcloud Load Balancer under /ipLoadbalancing.
For a comprehensive reference to the API functions of the OVHcloud Load Balancer service, please consult this detailed guide.
The Frontends, Farms and Servers are specific to the protocol (HTTP, TCP or UDP) in which they are defined. Compatibility between these components is only possible within the same protocol. For example, an HTTP Frontend can only be paired with an HTTP Farm, and cannot be used with a UDP Farm.
Each category that falls under Frontend, Farm and Server management consists of 3 API functions, one for each protocol (HTTP, TCP or UDP). You must execute the API function that corresponds to the specific protocol of the desired service.
Frontend
Return the list of IDs of existing frontends
Create a frontend
Return the parameters applied to a frontend
Delete a frontend
Server farm
Return the list of IDs of existing farms
Create a Farm
Return the parameters applied to a farm
Delete a Farm
Server
Return the list of server IDs linked to a particular farm
Creates a server for a particular farm
Return the parameters of a particular server
Edit settings for a particular server
Delete a server
SSL certificates
Return the list of SSL certificates
Create an SSL certificate
Return the settings for a particular SSL Certificate
Delete an SSL certificate
Tasks
Applies the changes to the Load Balancer configuration
Return the list of task IDs
Return the status of a particular task
