Multi-AZ architectures for OVHcloud Connect
Ver como Markdown
Understand how Multi-AZ architectures enhance resilience for OVHcloud Connect
Multi-AZ (Multiple Availability Zones) is an architecture strategy where your resources and network connections are distributed across two or more physically separated data centres (Availability Zones) within a region. This protects against the failure of a single site.
Why Multi-AZ matters for OVHcloud Connect
A single OVHcloud Connect link through a single PoP is a single point of failure. If that PoP, the cross-connect, or the physical link experiences an outage, your private connectivity is lost.
Multi-AZ designs address this by establishing redundant connections through different PoPs or Availability Zones, so that traffic can automatically reroute if one path fails.
Architecture overview
Multi-AZ architecture with redundant OVHcloud Connect links through separate PoPs and Availability Zones
How Multi-AZ works with OVHcloud Connect
  1. Order two OVHcloud Connect services in two different PoPs.
  2. Configure BGP on both links with appropriate route priorities (using BGP attributes like Local Preference, MED, or AS-path prepending) so that traffic prefers one path but can fall back to the other.
  3. Distribute your OVHcloud resources across multiple Availability Zones within the same region.
  4. Test failover by simulating a link outage and verifying that traffic switches to the backup path.
Multi-AZ and BGP configuration
For automatic failover, your BGP configuration must distinguish between the primary and backup paths. Common approaches:
  • Local Preference — Set a higher Local Preference on routes learned from the primary link.
  • AS-path prepending — Make the backup path's AS-path longer so it is less preferred.
  • MED (Multi-Exit Discriminator) — Use MED values to influence inbound routing from OVHcloud.
See Configure OCC L3 with BGP for detailed configuration guidance.
When to use Multi-AZ
ScenarioRecommendation
Test / development workloadsSingle connection is usually sufficient
Non-critical productionSingle connection with monitoring
Business-critical productionMulti-AZ recommended
Regulated / compliance workloadsMulti-AZ required
What's next?
For training or technical assistance implementing our solutions, contact your sales representative or visit our Professional Services page to request a quote and have your project analyzed by our experts.
