For AI agents: the complete documentation index is available at https://docs.ovhcloud.com/pt/llms.txt, the full documentation bundle is available at https://docs.ovhcloud.com/pt/llms-full.txt, and this page is available as Markdown at https://docs.ovhcloud.com/pt/guides/public-cloud/data-platform/tutorials-project-checklist.md.
Project checklist and best practices
Ver como Markdown
You have decided to go along and you have just spun up your Project! As the first users of our platform we
You have decided to go along and you have just spun up your Project! Great!
What's next? Where to start?
As the first users of our platform we, have accumulated several years of experience in carrying out data Projects. We have curated a list of best practices, learned through our services practice over the years, which we are excited to share with you.
Projects on Data Platform allow you to gather a team and work together on the same data Project. You can start with some basic file uploading and seamlessly switch to near real-time data processing, keeping your methodology and easily scaling as your Project grows.
So start, iterate, and grow your Project step-by-step: your Project will meet your growing needs.
A typical Project often goes through the following main milestones:
Checklist
We recommend you go through our Getting Started guide so you get a good understanding of the key Project components and Data Platform concepts.
Before take-off, here are some basic checks on your use case scope and agenda that we share with you:
  • Data sources
    • Which data do you need?
    • Is data available? How? Is data history available?
    • Storage sizing: how much data volume and compute will this Project require?
    • How often should it be refreshed?
  • Describe your own personal data book:
    • The "data story": where does it come from? How has it been produced? Your data flow history?
    • Data fields: what does it mean? what is it for?
    • Detailed Business Rules (about data)
    • KPI: how to compute them? what do they mean?
  • What is to be produced?
    • UX Storyboard
    • API for external use
    • Exporting files
  • Risk detection and mitigation
    • What could go wrong? What is intricate in your Project?
    • Identify/anticipate possible bottlenecks or hurdles
  • Identify & Leverage short iterations
  • View and check data as early as possible
  • Release early, release often!
User Management
Projects make it easy to work as a team on a Project. There are two levels of team management:
  • Members of your Data Platform organization are your teammates. They have created a Data Platform account
  • Users in your Project are either teammates working on this Project, or end-users of your API and apps
    • Members of an organization are automatically added as users in all Projects in this organization. Permissions must be granted manually to non-admins.
After adding your team to your organization, check how to give them access rights in each Project's Identity Access Manager according to their skills and permissions.
Your end-users access rights are also managed in the Identity Access Manager.
Manage resources
Projects were designed from scratch to scale easily as the requirements of your data Project evolve. You can independently scale horizontally and vertically any component of your choice in just a few clicks, for example your apps.
Each component in your Project will consume resources when it is actively running (either through a job or a deployment).
Even when it is idle, your Project uses a handful of DPUs by default. You can manage this amount in the Control Center.
Learn more about resource consumption
Collect data
Take a look at available connectors and remember that it is always possible to write a custom action to do whatever is not already possible through the interface.
If you need to manage files in your Project, we recommend using the Lakehouse Manager buckets:
  • organize buckets either by topic (referentials for instance), by type of processing or by providers depending on your needs
  • within a bucket, you can use folders to better organize your files
  • when defining a source, the Data Platform Buckets connector allows you to select a bucket then select files as sources
  • if you have multiple files in the same bucket/folder:
  • check out how to send files to the buckets with S31-compatible tools to integrate in your in-house process
Analyze data and design blueprint rules
Once you have set up your sources, take the time to analyze them and configure basic source cleaning rules called blueprint rules. This can help fix some common issues such as:
  • date formatting
  • number formatting
  • clean up strings
  • skip incomplete lines
  • ... and much more
In the long run, this step will save you a lot of time!
Organize data
The Tables page is where you prepare your database schema.
Tables
  • We recommend using a prefix depending on the type of data:
    • ref_: for referentials and stable data, without any temporal information
    • raw_: data imported as is with minimal changes. This can be used to trace back data issues
    • prm_: primary tables, i.e. improved quality data from raw_
    • fct_: consolidating facts from several prim_ and ref_ in a common scale
    • agr_: aggregation of data on a different scale (for instance datetime to date or date to year)
      • they are usually designed to optimize queries
      • build one agr_ table per scale granularity adding all needed attributes
      • then add attributes names that indicate granularity (agr_station_yearmonth, agr_movie_date)
    • tmp_: temporary tables used for processing (mark them as not queryable)
    • mlm_: for tables used in a machine learning model
  • Give clear names that describe what one row of data represents
  • Define indexes to speed up data operations
Attributes
Use Attributes tab to review all attributes, in which tables they are used, which DPE Actions uses it, etc.
Here are some best-practices about attributes (i.e. field names in tables):
  • attribute type: choose between dimension or measure
    • dimension: qualitative information that can be scaled by, filtered by, etc but not summed.
    • measure: numerical information that can, most of the time, be summed, counted, averaged, etc.
  • attribute naming:
    • use a prefix to distinguish them (e.g. client_, fb_, site_)
    • name measure attributes so they give a hint on a temporal window:
      • _nb_ : number for that day
      • _total_ : value for this day
      • _diff_ : difference from previous day
    • clearly indicate what it is (i.e. _amount_, _ticket_, _fans_)
    • give unit of measure if not obvious (i.e. _g, _kg, _wh, _kwh, _eur, _usd)
It is very important to use the same attribute name and type across all tables to name the same piece of information. Thus when playing a query in the Analytics Manager, it dynamically checks the most suitable object for required fields.
Explorer
Use Explorer to quicly check table contents.
Process data
The Data Processing Engine (DPE) is used to build actions which are the heart of your physical data flow. They can run alone or organized into groups named workflows.
Actions
Make sure you have a deep look at provided actions types.
If you need to go further, start writing a Custom Action using our SDK to interact with the rest of your Project leveraging Python or PySpark.
Use the notebooks to quickly prototype a Custom Action, then export it to the Data Processing Engine
  • For Aggregate Actions:
    • scale: must be the same granularity as the primary key of the destination table
    • double check your rules for joining tables: this is the main source of errors
  • Set log level appropriately during lifecycle (i.e. debug if needed, info otherwise)
  • Use Auto flush all to flush all caches and visualize the updates brought by the action on the datasets
Use Repositories and Versions
As your Project grows, don't forget you can organize actions in repositories using versions according to your needs.
Actions are listed in alphabetical order: you can add prefixes such as numbers to better organize them.
Use segmentation
To leverage the full power of the Data Platform's DPE, use Segmentation to parallelize computing tasks at an action's level.
Use a perimeter
To limit an action or a workflow on a subset of your data, e.g. for last 30 days, use the Perimeter option.
Write queries
Use folders and repositories to organize saved queries in the Analytics Manager.
For instance:
  • Data Quality: queries to check Data Quality
  • Data Analysis: queries to view basic features
  • App-xxx: prepare queries to use inside your Application
    • This allows you to update the database schema and the queries without having to deploy a new app version
    • Give clear, descriptive names to your queries
Query Engine
Build applications
Take the time to understand Application Services and the possible settings.
Helpful tips
  • Design a Storyboard before starting your Project
  • Make sure your dynamic parameters are present in all tables you need to request
  • Use object's label in Tables for automatic translation
  • Leverage Formatters and Translations
  • Leverage Style templates to streamline your Apps development
A typical application development lifecycle is:
  1. Design a storyboard
  • check data is available
  • identify dynamic parameters
  • identify needed charts and custom components
  1. Analytics Manager: prepare and check needed queries
  2. Implement a first version in the UI
  • set up dynamic parameters
  • set up dashboards and menus
  • set up available charts as needed
  • set up dictionaries, formatters and translations
  1. Improve that version
  1. Test and iterate again
  2. Give access to more users
Customize your application further
Application is based upon the ReactJS framework. We strongly recommend you go through our guide on advanced app customization.
Git repositories
It is usually recommended to synchronize your application with a Git repository and deploy two applications:
  • my-develop: synchronized with your develop branch
  • my-master: synchronized with your master branch
Custom Domain Names
By default, your application is available at :
https://my-project.eu.dataplatform.ovh.net/my-develop-app/
You may change it easily in the App's settings to be :
https://my-beautiful-app.eu.dataplatform.ovh.net/
If you need further customization, you may register your own domain and provide your own SSL certificates :
https://my-beautiful-app.example.com/
Give access to your application
By default, every Application created in Application Services has its counterpart in the Identity Access Manager.
  • Application Services
    • it manages the instance that will be deployed and run
    • it is linked to an Identity Application Manager's Application
    • it will use that IAM App configuration about Auth Providers, Users, etc
  • Identity Access Manager, you can define:
    • Logo
    • Application Title
    • Allowed Authentication Provider
Add all the end-users that will have access to your application (using authentication providers if your company has a SSO provider), and use roles and groups to manage data access control.
Front API
Default Front API checks authentication, process App's requests adding dynamic parameters and implementing ACLs.
Here are some scenarios where custom API is needed.
  • Implement transformers
  • Implement custom "evolution"
  • Implement complex ACL
Monitor
Control Center gives access to:
Project Backup
Project Configuration
Learn more about how to backup and restore your Project configuration.
Exporting data
Using a Data Processing Engine custom Action, you can export all your data to a bucket in the Lakehouse Manager.
Esta página foi útil?
