For AI agents: the complete documentation index is available at https://docs.ovhcloud.com/pt/llms.txt, the full documentation bundle is available at https://docs.ovhcloud.com/pt/llms-full.txt, and this page is available as Markdown at https://docs.ovhcloud.com/pt/guides/public-cloud/data-platform/connectors-sources-stripe-technical-reference.md.
Stripe: Technical Reference
Ver como Markdown
This is the technical companion to the main Stripe connector documentation
This is the technical companion to the main Stripe connector documentation. It covers authentication internals, the full endpoint reference, pagination, rate limits, output format, and limitations, everything needed to integrate the connector into a data pipeline.
Authentication
Method
Bearer token with the Stripe Secret API Key.
Authorization: Bearer sk_test_XXXXXXXXXXXXXXXX
The key is set once when the connector initializes; every subsequent API call reuses the same authenticated session.
Key Formats
PrefixTypeUsage
sk_test_Secret key (test)Sandbox, full API, fake data
sk_live_Secret key (live)Production, real transactions
rk_test_ / rk_live_Restricted keyScoped permissions (read-only recommended)
pk_test_ / pk_live_Publishable keyClient-side only, cannot be used here
Health Check
The connector's health check calls GET /v1/balance: a lightweight endpoint available on every Stripe account. A successful 200 response confirms the Secret key is valid.
Architecture
Raw JSON, platform-handled schema
The connector returns raw JSON from the Stripe API, arrays of Stripe objects with their full nested structure. The platform takes over from there:
  1. Schema is auto-discovered from the JSON payload
  2. Nested objects are flattened into dot-notation columns
  3. Data is stored in the lakehouse, queryable via SQL
You don't define a schema, list columns, or write any transformation code, any new field Stripe adds to an object appears automatically on the next extraction.
Uniform API, uniform connector
Stripe's list endpoints are exceptionally uniform: every one returns the same envelope, {"object":"list","data":[..],"has_more":bool}, and uses the same cursor-based pagination. Because of this, the connector uses a single extraction path for all 76 supported resources. Adding a new resource means adding its API path to a registry; no new extraction logic is needed.
Endpoint resolution
Endpoints are organized in the UI in three layers:
  1. Domain groups (core, billing, products, ...): you select a group, then pick the specific resource from a dropdown (e.g. billing → invoices).
  2. Standalone endpoints (payment_methods, tax_registrations, ...): the endpoint directly identifies the resource; no dropdown needed.
  3. Custom endpoint (custom): you type any Stripe API path (e.g. issuing/settlements) and the connector calls it with standard cursor pagination.
Whichever path you choose, the extraction behavior is identical: authenticate, paginate, return raw JSON.
What the connector handles vs what the platform handles
ResponsibilityOwner
Authentication (Bearer token)Connector
Pagination (cursor, has_more loop)Connector
Automatic retry on 429Connector
One-time fallback when an endpoint rejects limitConnector
Raw JSON outputConnector
Schema discovery from JSONPlatform
Flattening nested objects into columnsPlatform
Column naming (slugification, lowercase, underscores)Platform
Storage in the lakehousePlatform
Endpoint Reference
All list endpoints follow the same pattern: GET /v1/{resource}?limit=100&starting_after={cursor}. Responses share the same envelope: {"object":"list","data":[...],"has_more":bool,"url":"/v1/..."}.
The tables below document the 20 endpoints exposed in the UI and the Stripe resources they cover.
core
Main payment resources. Single domain group with a "Resource Type" dropdown (14 options).
ResourceAPI pathDescription
customers/v1/customersCustomer profiles
charges/v1/chargesCharges (legacy, kept for backward compat)
payment_intents/v1/payment_intentsModern payment flow (recommended over charges)
balance_transactions/v1/balance_transactionsAll balance movements
payouts/v1/payoutsBank payouts
refunds/v1/refundsRefunds
disputes/v1/disputesPayment disputes
setup_intents/v1/setup_intentsSetup flow for saving payment methods
events/v1/eventsWebhook event log
files/v1/filesUploaded files
file_links/v1/file_linksShareable file URLs
webhook_endpoints/v1/webhook_endpointsConfigured webhook receivers
payment_method_configurations/v1/payment_method_configurationsWhich payment methods to display
payment_method_domains/v1/payment_method_domainsDomain verification for methods
UI options: Resource Type (required, dropdown with the 14 resources above) + Max Items (optional). Pagination: cursor-based. Output: Raw JSON. Stripe list envelope.
products
Catalog and pricing (7 options).
ResourceAPI path
products/v1/products
prices/v1/prices
coupons/v1/coupons
promotion_codes/v1/promotion_codes
tax_codes/v1/tax_codes
tax_rates/v1/tax_rates
shipping_rates/v1/shipping_rates
UI options: Resource Type (required) + Max Items (optional). Pagination: cursor-based. Output: Raw JSON.
billing
Recurring billing (11 options).
ResourceAPI path
subscriptions/v1/subscriptions
subscription_schedules/v1/subscription_schedules
invoices/v1/invoices
invoice_items/v1/invoiceitems
invoice_rendering_templates/v1/invoice_rendering_templates
credit_notes/v1/credit_notes
plans/v1/plans
quotes/v1/quotes
billing_meters/v1/billing/meters
billing_alerts/v1/billing/alerts
billing_credit_grants/v1/billing/credit_grants
Notable quirk: per Stripe's API docs, the subscriptions list endpoint returns all subscriptions that have not been canceled by default (active, trialing, past_due, incomplete, unpaid, paused). Canceled subscriptions are excluded unless you ask for them explicitly. To include canceled ones, use the custom endpoint with resource_path=subscriptions?status=canceled or ?status=all.
checkout
Hosted checkout flows (2 options: checkout_sessions, payment_links).
connect
Marketplace / platform resources (5 options: accounts, application_fees, transfers, top_ups, country_specs).
radar
Fraud detection: requires Stripe Radar (3 options: early_fraud_warnings, reviews, value_lists).
issuing
Card issuing: requires Stripe Issuing activation (7 options: authorizations, cardholders, cards, transactions, disputes, personalization_designs, physical_bundles).
UI options: Resource Type (required) + Max Items (optional). Pagination: cursor-based. Behavior if product is not enabled: Stripe returns 400 Bad Request with the message "Your account is not set up to use Issuing". The extraction fails, see Limitations.
treasury
Money movement: requires Stripe Treasury activation (9 sub-resources).
ResourceAPI path
treasury_transactions/v1/treasury/transactions
treasury_transaction_entries/v1/treasury/transaction_entries
treasury_outbound_transfers/v1/treasury/outbound_transfers
treasury_outbound_payments/v1/treasury/outbound_payments
treasury_inbound_transfers/v1/treasury/inbound_transfers
treasury_received_credits/v1/treasury/received_credits
treasury_received_debits/v1/treasury/received_debits
treasury_credit_reversals/v1/treasury/credit_reversals
treasury_debit_reversals/v1/treasury/debit_reversals
UI options: Resource Type (required) + Financial Account ID (required, format fa_xxx) + Max Items (optional). Pagination: cursor-based.
terminal
Physical card readers (3 options: terminal_locations, terminal_readers, terminal_configurations).
identity
Identity verification: requires Stripe Identity (2 options: identity_verification_sessions, identity_verification_reports).
climate
Carbon removal: requires Stripe Climate (3 options: climate_orders, climate_suppliers, climate_products).
reporting
Reports and Sigma (3 options: report_runs, report_types, sigma_scheduled_query_runs).
Notable quirk: /v1/reporting/report_types rejects the limit parameter. The connector detects this, drops the parameter, and retries automatically. No action needed on your side.
payment_methods (filtered standalone)
UI options: Customer ID (required, format cus_xxx) + Max Items (optional). Lists payment methods attached to a specific customer. Stripe requires the customer filter, if the Customer ID is missing, the connector returns an empty list instead of making the API call.
setup_attempts (filtered standalone)
UI options: Setup Intent ID (required, format seti_xxx) + Max Items (optional).
subscription_items (filtered standalone)
UI options: Subscription ID (required, format sub_xxx) + Max Items (optional).
financial_connections_transactions (filtered standalone)
UI options: Account ID (required, format fca_xxx) + Max Items (optional).
financial_connections_accounts (standalone)
UI options: Max Items only. Lists all Financial Connections accounts linked to the Stripe account.
tax_registrations (standalone)
treasury_financial_accounts (standalone)
UI options: Max Items only. Note: the individual transaction endpoints are in the treasury domain group. This standalone endpoint is only for the accounts list itself.
custom
UI options: Resource Path (required) + Max Items (optional).
Free-text Stripe API path. The connector accepts the path with or without a leading v1/ prefix, and calls the endpoint with standard cursor pagination.
Example inputs:
  • issuing/settlements → GET /v1/issuing/settlements
  • v1/capital/financing_offers → GET /v1/capital/financing_offers (no double prefix)
Use this endpoint for Stripe resources that aren't covered by a named endpoint yet, or for niche/beta endpoints where a named slot isn't warranted.
Pagination
All list endpoints use Stripe's cursor-based pagination:
GET /v1/{resource}?limit=100&starting_after={last_id}
Response:
  "object": "list",
  "url": "/v1/...",
  "has_more": true,
  "data": [ ... ]
Behavior you can expect:
  • The connector fetches 100 records per request (Stripe's maximum page size)
  • It continues paginating as long as Stripe reports has_more: true
  • It stops when has_more is false, or when Max Items is reached
No-limit fallback
A small number of Stripe endpoints (notably /v1/reporting/report_types) don't accept the limit parameter. The connector detects the resulting 400 error, retries the request without limit, and continues the extraction transparently. You don't need to configure anything. The retry is automatic and only happens on the first request.
See Stripe Pagination docs for the complete specification.
Rate Limits
Stripe documents rate limits at docs.stripe.com/rate-limits. Exact numbers depend on the endpoint and account type, refer to the official documentation for current limits.
Rate Limit Handling
On 429 Too Many Requests, the connector waits and retries automatically:
  1. It reads the Retry-After header sent by Stripe (in seconds)
  2. If the header is missing, it falls back to a 2-second wait
  3. It then retries the same request and continues the extraction
All other error codes (400, 401, 403, 404, 500, etc.) propagate as failures. The connector does not catch or skip them. The extraction stops immediately with the error returned by Stripe.
Output Format
Raw JSON (connector output)
The connector returns raw JSON from the Stripe API, arrays of Stripe objects with their full nested structure, matching Stripe's object schemas exactly.
Every Stripe object contains:
FieldDescription
idUnique ID with type prefix (cus_, ch_, sub_, pi_, in_, etc.)
objectObject type (customer, charge, subscription, ...)
createdUnix timestamp (seconds)
livemodeBoolean, test vs live mode
metadataUser-defined key-value map
Resource-specific fields vary per object. Refer to Stripe API reference for each object's schema.
Flattened output (lakehouse)
The platform flattens the raw JSON into a flat table. Nested keys become column names with underscores:
Raw JSON pathLakehouse column
idid
objectobject
createdcreated
address.countryaddress_country
metadata.custom_keymetadata_custom_key
Column names are normalized: lowercase, dots and special characters replaced by underscores, always starting with a letter or underscore.
Limitations
  • No deletion tracking: the connector extracts the current state of each resource. Deleted objects are typically not returned by list endpoints. For an audit trail, extract events (which records deletions as *.deleted event types).
  • Unix timestamps: Stripe uses Unix seconds (integer), not ISO 8601 strings. Cast to timestamp in downstream queries.
  • Stripe product gating: Issuing, Treasury, Identity, Terminal, and Climate require the corresponding Stripe product to be activated on the account. If not activated, Stripe returns a 400 error with a message like "Your account is not set up to use X" and the extraction fails. The connector does not skip or retry.
  • Permission errors are not skipped: if Stripe returns a 403 (permission denied), for example, because your Restricted API Key lacks read access to a resource, the extraction fails immediately. The connector doesn't have special handling to turn 403s into empty results; it only retries on 429 rate-limit responses.
  • subscriptions default filter: per Stripe's API docs, the list endpoint returns all subscriptions that have not been canceled by default. To include canceled subscriptions, use the custom endpoint with resource_path=subscriptions?status=canceled or ?status=all.
  • Custom endpoint pagination: the custom endpoint assumes Stripe's standard list response format ({"object":"list","data":[...],"has_more":bool}). Endpoints with a non-standard response shape (e.g. singletons like /v1/balance) will return an empty list.
  • Test mode vs live mode isolation: the Secret key determines which environment the connector reads from. sk_test_ and sk_live_ data are completely isolated. There is no cross-environment extraction.
  • No automatic expansion: Stripe supports expand[]=field to inline related objects, but the connector does not set this. Related objects appear as ID references in the output; join them downstream via a separate extraction.
Esta página foi útil?
