For AI agents: the complete documentation index is available at https://docs.ovhcloud.com/de/llms.txt, the full documentation bundle is available at https://docs.ovhcloud.com/de/llms-full.txt, and this page is available as Markdown at https://docs.ovhcloud.com/de/guides/public-cloud/containers-orchestration/managed-kubernetes/expose-applications-using-load-balancer.md.
Zum Inhalt springen
Expose your applications using OVHcloud Public Cloud Load Balancer
Als Markdown ansehen
How to expose your applications hosted on Managed Kubernetes Service using the OVHcloud Public Cloud Load Balancer
Usage of the Public Cloud Load Balancer with Managed Kubernetes Service (MKS) is now in General Availability. However this LoadBalancer (based on Octavia project) is not the default one yet for clusters running Kubernetes versions <1.31. For those clusters, you must use the annotation loadbalancer.ovhcloud.com/class: octavia to deploy an Octavia LoadBalancer from your MKS cluster. See also How to migrate from Load Balancer for MKS (IOLB) to Public Cloud Load Balancer (Octavia).
This guide aims to explain how to use OVHcloud Public Cloud Load Balancer to expose your applications hosted on Managed Kubernetes Service (MKS). If you're not comfortable with the different ways of exposing your applications in Kubernetes, or if you're not familiar with the notion of 'loadbalancer' service type, we recommend starting by reading the guide explaining how to expose your application deployed on an OVHcloud Managed Kubernetes Service. This guide details the different methods to expose your containerized applications hosted in Managed Kubernetes Service.
Our Public Cloud Load Balancer is relying on the OpenStack Octavia project which provides a Cloud Controller Manager (CCM) allowing Kubernetes clusters to interact with Load Balancers. For Managed Kubernetes Service (MKS), this Cloud Controller is installed and configured by our team, allowing you to easily create, use and configure our Public Cloud Load Balancers. You can find the CCM open-source project documentation here.
This guide uses some concepts that are specific to our Public Cloud Load Balancer (listener, pool, health monitor, member, ...) and to the OVHcloud Public Cloud Network (Gateway, Floating IP). You can find more information regarding Public Cloud Network concepts in our official documentation, for example networking concepts and loadbalancer concepts.
Kubernetes version
To be able to deploy Public Cloud Load Balancer, your Managed Kubernetes Service must run or have been upgraded to the following patch versions:
Kubernetes versions
1.29.3-3 >=
1.30.2-1 >=
Please note that for clusters running on those versions, you must use the annotation loadbalancer.ovhcloud.com/class: octavia to specify that you want to deploy Public Cloud Load Balancer (based on Octavia project) for your MKS cluster.
The following versions will use Public Cloud Load Balancer as the default load balancing solution, you do not need to specify any annotation:
Kubernetes versions
1.31 >=
Network prerequisite to expose your Load Balancers publicly
The first step is to make sure that you have an existing vRack on your Public Cloud Project. To do so you can follow this guide that explains how to Configure a vRack for Public Cloud.
If you plan to expose your Load Balancer publicly, in order to attach a Floating IP to your Load Balancer, it is mandatory to have an OVHcloud Gateway (an OpenStack router) deployed on the subnet hosting your Load Balancer.
If it does not exist when you create your first Public Cloud Load Balancer, an S size Managed Gateway will be automatically created. That is why we recommend deploying your MKS clusters on a network and subnet where an OVHcloud Gateway can be created (manually or automatically - cf. Creating a private network with Gateway) or is already existing.
If you have an existing/already deployed cluster and if:
  • The Subnet's GatewayIP is already used by an OVHcloud Gateway, nothing needs to be done. The current OVHcloud Gateway (OpenStack Router) will be used.
  • The subnet does not have an IP reserved for a Gateway, you will have to provide or create a compatible subnet. Three options are available:
    • Edit an existing subnet to reserve an IP for a Gateway : please refer to the Update a subnet properties documentation.
    • Provide another compatible subnet: a subnet with an existing OVHcloud Gateway or with an IP address reserved for a Gateway (Creating a private network with Gateway)
    • Use a subnet dedicated for your load balancer: this option can be used in the OVHcloud Console, in the Load Balancer subnet field of the Network settings section when creating the cluster, or using APIs/Infra as Code using the loadBalancersSubnetId parameter.
  • The GatewayIP is already assigned to a non-OVHcloud Gateway (OpenStack Router). Two options are available:
    • Use a subnet dedicated for your load balancers: this option can be used in the OVHcloud Console, in the Load Balancer subnet field of the Network settings section when creating the cluster, or using APIs/Infra as Code with the loadBalancersSubnetId parameter.
Limitations
  • On a Standard cluster created with disablePublicNetworking (public exposure of nodes and workloads disabled, including clusters using your own router as default gateway), no public Load Balancer can be created: Services of type LoadBalancer cannot be exposed on the Internet. See Using a custom gateway on an OVHcloud Managed Kubernetes cluster.
  • Layer 7 Policy & Rules and TLS Termination (TERMINATED_HTTPS listener) are not available yet. For such use cases you can rely on Octavia Ingress Controller
  • Proxy Protocol is only supported for TCP services.
Billing
When exposing your load balancer publicly (public-to-public or public-to-private):
  • If it does not already exist, a single OVHcloud Gateway will be automatically created and billed for all Load Balancers spawned in the subnet: Gateway pricing.
  • A Public Floating IP will be used: Floating IP pricing.
  • Each Public Cloud Load Balancer is billed according to its flavor: Load Balancer pricing.
Note: Each publicly exposed Load Balancer has its own Public Floating IP. Outgoing traffic doesn't consume OVHcloud Gateway bandwidth. (except for Public-to-Public mode)
Depending on the Kubernetes version your cluster is using, if you want to use a Public Cloud Load Balancer rather than the historical Loadbalancer for Kubernetes solution, you might need to add the annotation: loadbalancer.ovhcloud.com/class: "octavia" on your Kubernetes Service manifest. Please refer to the versions matrix section.
Here's a simple example of how to use the Public Cloud Load Balancer
1. Deploy a functional Managed Kubernetes (MKS) cluster using the , Terraform, Pulumi or the .
2. Retrieve the kubeconfig file needed to use kubectl tool (via the OVHcloud Console, Terraform, Pulumi or API). You can use this guide.
3. Create a Namespace and a Deployment resource using the following command:
kubectl create namespace test-lb-ns
kubectl create deployment test-lb --image=nginx -n=test-lb-ns
4. Copy/paste the following code on a file named test-lb-service.yaml:
apiVersion: v1
kind: Service
metadata:
  labels:
    app: test-lb
  namespace: test-lb-ns
  annotations:
    loadbalancer.ovhcloud.com/class: octavia //not required for cluster running kubernetes versions >= 1.31
    # Use `openstack loadbalancer flavor list` to get the full list of available flavors.
    loadbalancer.ovhcloud.com/flavor: small # Name of a loadbalancer flavor, used in MKS Free ONLY.
    loadbalancer.openstack.org/flavor-id: xxx # UUID of a loadbalancer flavor, used in MKS Standard ONLY.
spec:
  ports:
    - name: 80-80
      port: 80
      protocol: TCP
      targetPort: 80
  selector:
      app: test-lb
  type: LoadBalancer
5. Create a 'Service' using the following command:
kubectl apply -f test-lb-service.yaml
6. Retrieve the Service IP address using the following command line:
$ kubectl get service test-lb-service -n=test-lb-ns
NAME                 TYPE           CLUSTER-IP    EXTERNAL-IP      PORT(S)        AGE
test-lb-service      LoadBalancer   10.3.107.18   141.94.215.240   80:30172/TCP   12m
7. Open a web browser and access: http://141.94.215.240
Use cases
You can find a set a examples on how to use our Public Cloud Load Balancer with Managed Kubernetes Service (MKS) on our dedicated Github repository: https://github.com/ovh/public-cloud-examples
Public-to-Private (your cluster is attached to a private network/subnet)
In a public-to-private scenario you will use your Load Balancer to publicly expose applications that are hosted on your Managed Kubernetes Cluster. The main benefit of this scenario is that your Kubernetes nodes are not exposed on the Internet.
Service example:
apiVersion: v1
kind: Service
metadata:
  annotations:
    loadbalancer.ovhcloud.com/class: "octavia" //not required for cluster running kubernetes versions >= 1.31
    # When not specified, the "small" flavor is used by default.
    loadbalancer.ovhcloud.com/flavor: medium # Name of a loadbalancer flavor, used in MKS Free ONLY.
    loadbalancer.openstack.org/flavor-id: yyy # UUID of a loadbalancer flavor, used in MKS Standard ONLY.
  labels:
    app: test-octavia
spec:
  ports:
  - name: client
    port: 80
    protocol: TCP
    targetPort: 80
  selector:
    app: nginx
  type: LoadBalancer
Private-to-Private
In a private-to-private scenario your Load Balancer is not exposed publicly, it may be useful if you want to expose your containerized service inside your OVHcloud private network.
Service example:
apiVersion: v1
kind: Service
metadata:
  annotations:
    service.beta.kubernetes.io/openstack-internal-load-balancer: "true"
  labels:
    app: test-octavia
spec:
  ports:
  - name: client
    port: 80
    protocol: TCP
    targetPort: 80
  selector:
    app: nginx
  type: LoadBalancer
Public-to-Public (you are using a public Managed Kubernetes Cluster)
In a public-to-public scenario, all your Kubernetes nodes have a public network interface. Inter-node/pod communication will rely on public network. This is the easiest way to deploy a MKS cluster as it does not require to create a network and subnet topology. Although all your nodes already carry a public IP address for exposing your applications, you can choose to use a loadbalancer to expose them behind a single IP address.
Service example:
apiVersion: v1
kind: Service
metadata:
  annotations:
  labels:
    app: test-octavia
spec:
  ports:
  - name: client
    port: 80
    protocol: TCP
    targetPort: 80
  selector:
    app: nginx
  type: LoadBalancer
A single OpenStack Gateway is spawned for all your LoadBalancers, the Gateway is a small one by default. In Public-To-Public mode, the gateway may throttle your LoadBalancers's capacity. To increase the capacity of an OpenStack router, use the to modify your gateway with a larger size (Gateway under Network > ... > Modify size).
Supported Annotations & Features
Supported service annotations
  • loadbalancer.ovhcloud.com/class
Authorized values: 'octavia' = Public Cloud Load Balancer, 'iolb' = Loadbalancer for Managed Kubernetes Service (will be deprecated in future versions). If not specified, the default class of the MKS Kubernetes versions you are using will be applied, please refer to the versions matrix section.
  • loadbalancer.ovhcloud.com/flavor (MKS Free only)
    Not a standard OpenStack Octavia annotation (specific to OVHcloud). The size used for creating the loadbalancer. Specifications can be found on the Load Balancer specifications page. Authorized values => small,medium,large, xl. Default is 'small'.
  • loadbalancer.openstack.org/flavor-id (MKS Standard only)
    The UUID of the flavor used to create the loadbalancer. To get the flavors UUIDs, install and configure the OVHcloud CLI and run:
    ovhcloud cloud reference loadbalancer list-flavors <REGION>
    $ ovhcloud cloud reference loadbalancer list-flavors EU-WEST-PAR
    │                  id                  │  name  │   region    │
    │ 222a6297-9d0b-42df-82a7-dcc83168868e │ medium │ EU-WEST-PAR │
    │ 472650bd-610d-40ed-9bb3-80e419a9fdcb │ large  │ EU-WEST-PAR │
    │ 472f72ea-3e6a-4633-bf23-0591bef5c553 │ small  │ EU-WEST-PAR │
    │ b753626b-12a2-4163-b277-208b4044e979 │ xl     │ EU-WEST-PAR │
    Alternatively, you can use the OpenStack CLI:
  • service.beta.kubernetes.io/openstack-internal-load-balancer
    If 'true', the loadbalancer will only have an IP on the private network (no Floating IP is associated with the Load Balancer). Default is 'false'.
  • loadbalancer.openstack.org/subnet-id
    The subnet ID where the private IP of the load balancer will be retrieved. By default, the subnet-id of the subnet configured for your OVHcloud Managed Kubernetes Service cluster will be used.
  • loadbalancer.openstack.org/member-subnet-id
    Member subnet ID of the load balancer created. By default, the subnet-id of the subnet configured for your OVHcloud Managed Kubernetes Service cluster will be used.
  • loadbalancer.openstack.org/network-id
    The network ID which will allocate the virtual IP for loadbalancer. By default, the network-id of the network configured for your OVHcloud Managed Kubernetes Service cluster will be used.
  • loadbalancer.openstack.org/port-id
    The port ID for load balancer private IP. Can be used if you want to use a specific private IP.
  • loadbalancer.openstack.org/connection-limit
    The maximum number of connections per second allowed for the listener. Positive integer or -1 for unlimited (default). This annotation supports update operations.
  • loadbalancer.openstack.org/keep-floatingip
    If 'true', the floating IP will NOT be deleted upon load balancer deletion. Default is 'false'. Useful if you want to keep your Floating IP after Load Balancer deletion.
  • loadbalancer.openstack.org/proxy-protocol
    Enable the ProxyProtocol on all listeners. Default is 'false'.
Values:
  • v1, true: enable the ProxyProtocol version 1
  • v2: enable the ProxyProtocol version 2
  • loadbalancer.openstack.org/timeout-client-data
    Frontend client inactivity timeout in milliseconds for the load balancer. Default value (s) = 50.
  • loadbalancer.openstack.org/timeout-member-connect
    Backend member connection timeout in milliseconds for the load balancer. Default value (s) = 5.
  • loadbalancer.openstack.org/timeout-member-data
    Backend member inactivity timeout in milliseconds for the load balancer. Default value (s) = 50.
  • loadbalancer.openstack.org/timeout-tcp-inspect
    Time to wait for additional TCP packets for content inspection in milliseconds for the load balancer. Default value (ms) = 0.
  • loadbalancer.openstack.org/enable-health-monitor
    Defines whether to create health monitor for the load balancer pool. Default is true. The health monitor can be created or deleted dynamically. A health monitor is required for services with spec.externalTrafficPolicy: Local.
  • loadbalancer.openstack.org/health-monitor-delay
    Defines the health monitor delay in seconds for the loadbalancer pools. Default value (ms) = 5000
  • loadbalancer.openstack.org/health-monitor-timeout
    Defines the health monitor timeout in seconds for the loadbalancer pools. This value should be less than delay. Default value (ms) = 3000
  • loadbalancer.openstack.org/health-monitor-max-retries
    Defines the health monitor retry count for the loadbalancer pool members to be marked online. Default value = 1
  • loadbalancer.openstack.org/health-monitor-max-retries-down
    Defines the health monitor retry count for the loadbalancer pool members to be marked down. Default value = 3
    The id of the flavor that is used for creating the loadbalancer: only in use for MKS Standard. MKS Free uses loadbalancer.ovhcloud.com/flavor.
  • loadbalancer.openstack.org/load-balancer-id
    This annotation is automatically added to the Service if it's not specified when creating. After the Service is created successfully it shouldn't be changed, otherwise the Service won't behave as expected.
    If this annotation is specified with a valid cloud load balancer ID when creating Service, the Service is reusing this load balancer rather than creating another one. More details below.
    If this annotation is specified, the other annotations which define the load balancer features will be ignored.
  • loadbalancer.openstack.org/hostname
    This annotation explicitly sets a hostname in the status of the load balancer service.
  • loadbalancer.openstack.org/load-balancer-address
    This annotation is automatically added and it contains the Floating IP address of the load balancer service. When using loadbalancer.openstack.org/hostname annotation it is the only place to see the real address of the load balancer.
  • loadbalancer.openstack.org/lb-method
    This annotation configures the load balancing algorithm to use to distribute new connections. Default algorithm: ROUND_ROBIN Others algorithms available: LEAST_CONNECTIONS, SOURCE_IP
This annotation is only available for the following MKS versions: 1.31.1-3+, 1.30.5-1+, 1.29.9-1+, 1.28.14-1+, 1.27.16-1+, 1.26.15-10+
Annotations not supported
Features
Resize your LoadBalancer
There is no proper way to "hot-resize" your loadbalancer yet (work in progress). The best alternative to change the flavor of your load balancer is to recreate a new Kubernetes Service that will use the same public IP as an existing one. You can find the complete HowTo and examples on our public Github repository: https://github.com/ovh/public-cloud-examples/tree/main/containers-orchestration/managed-kubernetes/use-public-cloud-load-balancer.
  • First, make sure that the existing service is using the loadbalancer.openstack.org/keep-floatingip annotation. If it's not using it, the public Floating IP will be released (it can be added after the service creation).
  • Get the public IP of your existing service:
$ kubectl get service my-small-lb
test-lb-todel        LoadBalancer   10.3.107.18   141.94.215.240   80:30172/TCP   12m
  • Create a new service with the new expected flavor:
  apiVersion: v1
  kind: Service
  metadata:
    annotations:
      loadbalancer.ovhcloud.com/class: "octavia" # not required for clusters running kubernetes versions >= 1.31
    labels:
      app: demo-upgrade
  spec:
    loadBalancerIP: 141.94.215.240 # Use the IP address from the previous service
    ports:
    - name: client
      port: 80
      protocol: TCP
      targetPort: 80
    selector:
      app: nginx
    type: LoadBalancer
  • Until the deletion of the previous service, this Service will only deploy the LoadBalancer without a Floating IP.
  • When the Floating IP is available (the deletion of the initial LB service will unbound the IP), the Floating IP will be attached to this new LB.
Changing the flavor will lead to a new LoadBalancer creation and deletion of the old LoadBalancer. During this change your applications may become inaccessible.
Use PROXY protocol to preserve client IP
When exposing services like nginx-ingress-controller, it's a common requirement that the client connection information could pass through proxy servers and load balancers, therefore visible to the backend services. Knowing the originating IP address of a client may be useful for setting a particular language for a website, keeping a denylist of IP addresses, or simply for logging and statistics purposes. You can follow the official Cloud Controller Manager documentation on how to Use PROXY protocol to preserve client IP.
Use an existing Floating IP in the tenant
To use an available Floating IP to your K8S LoadBalancer, use the field .spec.loadBalancerIP to find this Floating IP in your tenant.
  • If the Floating IP is not found, the LoadBalancer will be stuck during the provisioning
  • If the Floating IP is already assigned to another component, the LoadBalancer will be provisioned. The Floating IP will only be assigned when the Floating IP becomes available.
apiVersion: v1
kind: Service
metadata:
  annotations:
    loadbalancer.ovhcloud.com/class: "octavia" //not required for clusters running kubernetes versions >= 1.31
    # loadbalancer.openstack.org/keep-floatingip: "true" # Useless, since the FIP was provided, the FIP will not be managed by the MKS cluster
spec:
  loadBalancerIP: 1.2.3.4
  type: LoadBalancer
Note: the Floating IP must be in the same region as the MKS cluster. A Floating IP cannot be moved to another OpenStack region.
Use a fixed Virtual-IP (VIP) for the LoadBalancer in the subnet
To assign a fixed VIP to the LoadBalancer in the OpenStack subnet, you have to create an OpenStack Port. e.g. with the OpenStack CLI:
openstack port create --network <network> --fixed-ip subnet=<subnet>,ip-address=10.2.3.4 my-fixed-octavia-vip
Then use the annotation loadbalancer.openstack.org/port-id with the OpenStack port's UUID:
apiVersion: v1
kind: Service
metadata:
  annotations:
    service.beta.kubernetes.io/openstack-internal-load-balancer: "true" // most of the time, your LB is private in this case (but it's not mandatory)
    loadbalancer.openstack.org/port-id: "<openstack-port-uuid>"
spec:
  type: LoadBalancer
This feature is only supported when the MKS cluster is attached to a private network. (Public MKS is not supported) The port needs to belong to the same network/subnet as the MKS cluster. This feature is not compatible when the MKS cluster is configured with a LoadBalancerSubnetId (except if is the same as the NodeSubnetID).
Restrict access for a LoadBalancer Service
To apply IP restriction to the K8S LoadBalancer Service, you can define the array .spec.loadBalancerSourceRanges with a list of CIDR ranges.
apiVersion: v1
kind: Service
metadata:
  annotations:
spec:
  loadBalancerSourceRanges:
  - 1.2.3.4/32
  - 5.6.7.0/24
  type: LoadBalancer
If no value is assigned to this spec, no restriction will be applied.
Sharing an Octavia LoadBalancer between multiple Kubernetes LoadBalancer Services
You can share an Octavia LoadBalancer with up to two Kubernetes Services. These Services can be deployed on different MKS clusters (clusters must be in the same network).
K8S services must expose different protocol/port (you cannot set the same protocol/port on both K8S Services). Sharing load balancer with multiple Services (GitHub)
To allow another K8S LoadBalancer Service to use an existing Octavia (created via MKS or via OpenStack), use the annotation loadbalancer.openstack.org/load-balancer-id:
apiVersion: v1
kind: Service
metadata:
  annotations:
    loadbalancer.openstack.org/load-balancer-id: "<existing-octavia-uuid>"
spec:
  type: LoadBalancer
If you want to delete a MKS cluster which is using SharedLoadBalancer feature, we strongly recommend you to delete the K8S Service which is using it to avoid any issue (such as a remaining Octavia LoadBalancer, configuration not removed, ...).
Common issues when deploying a new LoadBalancer
If you encounter issues when trying to deploy a Public Cloud LoadBalancer, you can get more information using the kubectl describe service <svc_name> command. This will help you get events linked to the service for debugging purposes.
Network is not matching requirements for Public LoadBalancer: No GatewayIP
When trying to spawn a Public LoadBalancer, you must have a GatewayIP assigned to your Subnet to allow a FloatingIP in your subnet. Once the GatewayIP parameter is set with a valid IP, an OpenStack router will be spawned to attach a PublicIP to your Octavia LoadBalancer.
Error syncing load balancer: failed to ensure load balancer: Network is not matching requirement for Public LoadBalancer (no GatewayIP)
See the guide: How set a GatewayIP on an OpenStack Subnet.
If you don't want to deploy an OpenStack router in your subnet (e.g. you manage your own router), you have to configure the LoadBalancerSubnetId of your MKS cluster. More information here.
Network is not matching requirements for Public LoadBalancer: Cannot deploy an OpenStack Router
When trying to spawn a Public LoadBalancer, you must have a GatewayIP assigned to your Subnet to allow a FloatingIP in your subnet and this GatewayIP must be available or attached to an OpenStack router.
Error syncing load balancer: failed to ensure load balancer: Network is not matching requirement for Public LoadBalancer (cannot deploy an OpenStack Router)
In your case, the GatewayIP is already used by something else and we cannot deploy an OpenStack Router for your Public LoadBalancer. If you are not able to release the IP (e.g. it is used by a router you deployed), you have to configure the LoadBalancerSubnetId of your MKS cluster. More information here
Resources Naming Convention
When deploying LoadBalancer through Kubernetes Service with type LoadBalancer, the Cloud Controller Manager (CCM) implementation will automatically create Public Cloud resources (LoadBalancer, Listener, Pool, Health-monitor, Gateway, Network, Subnet,...). In order to easily identify those resources, here are the naming templates:
Do not change the name of resources automatically created by MKS, as it may result in inconsistencies.
ResourceNaming
Public Cloud Load Balancerkube_service_$mks_cluster_shortname_$namespace_$k8s_service_name
Listenerlistener_kube_service_$listener_n°$mks_cluster_shortname$namespace_$service-name
Poolpool_kube_service_$pool_n°$mks_cluster_shortname$namespace_$service-name
Health-monitormonitor_kube_service_$mks_cluster_shortname_$namespace_$service-name
Network (only automatically created in Public-to-Public scenario)k8s-cluster-$mks_cluster_id
Subnet (only automatically created in Public-to-Public scenario)k8s-cluster-$mks_cluster_id
Gateway/Routerk8s-cluster-$mks_cluster_id
Floating IPName = IP. Description= LB Octavia Name
Other resources
Visit the Github examples repository.
Visit our dedicated Discord channel: https://discord.gg/ovhcloud. Ask questions, provide feedback and interact directly with the team that builds our Container and Orchestration services.
War diese Seite hilfreich?
