For AI agents: the complete documentation index is available at https://docs.ovhcloud.com/de/llms.txt, the full documentation bundle is available at https://docs.ovhcloud.com/de/llms-full.txt, and this page is available as Markdown at https://docs.ovhcloud.com/de/guides/public-cloud/data-platform/connectors-sources-hubspot-technical-reference.md.
HubSpot: Technical Reference
Als Markdown ansehen
This is the technical companion to the main HubSpot connector documentation
This is the technical companion to the main HubSpot connector documentation. It covers authentication internals, the full endpoint reference, scopes, pagination, output format, and limitations, everything needed to integrate the connector into a data pipeline.
Authentication
Supported Methods
MethodFormatUse case
Private App Token (recommended)pat-na1-xxx or pat-eu1-xxxServer-side integrations
OAuth2 Access TokenStandard OAuth bearer tokenPublic distributed apps
All methods use the same Bearer header:
Authorization: Bearer {token}
Deprecated authentication methods
MethodWhy
API Key (hapikey)Sunset since November 2022
Personal Access KeyCLI only, which returns 401 on REST API calls
Credentials Format
  "token": "pat-eu1-xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx"
Architecture
The connector returns raw JSON from the HubSpot API. The platform takes over from there. It auto-discovers the schema from the JSON payload, flattens nested objects into dot-notation columns (slugified to lowercase with underscores), and stores the result in the lakehouse, queryable via Trino. Any new field HubSpot adds to an object appears automatically on the next extraction; you don't define a schema, list columns, or write any transformation code.
The connector itself is responsible for authentication (Bearer token), endpoint routing, pagination (cursor or offset depending on the endpoint), and rate-limit retries.
CRM Object Types
27 Standard Objects
The connector exposes the 27 standard HubSpot CRM object types. Each is reachable via /crm/v3/objects/{object_type} (except owners, see below).
Core CRM
Object TypeAPI Path
contacts/crm/v3/objects/contacts
companies/crm/v3/objects/companies
deals/crm/v3/objects/deals
tickets/crm/v3/objects/tickets
Engagements
Object TypeAPI Path
calls/crm/v3/objects/calls
emails/crm/v3/objects/emails
meetings/crm/v3/objects/meetings
notes/crm/v3/objects/notes
tasks/crm/v3/objects/tasks
communications/crm/v3/objects/communications
postal_mail/crm/v3/objects/postal_mail
E-commerce & Sales
Object TypeAPI Path
products/crm/v3/objects/products
line_items/crm/v3/objects/line_items
quotes/crm/v3/objects/quotes
Commerce
Object TypeAPI Path
invoices/crm/v3/objects/invoices
subscriptions/crm/v3/objects/subscriptions
orders/crm/v3/objects/orders
payments/crm/v3/objects/payments
Commerce Hub
Object TypeAPI Path
carts/crm/v3/objects/carts
discounts/crm/v3/objects/discounts
fees/crm/v3/objects/fees
taxes/crm/v3/objects/taxes
Sales Hub
Object TypeAPI PathNotes
leads/crm/v3/objects/leadsSales Hub Pro+
goals/crm/v3/objects/goals
Service & Scheduling
feedback_submissions/crm/v3/objects/feedback_submissionsService Hub
appointments/crm/v3/objects/appointmentsScheduling
services/crm/v3/objects/services
Special: Owners
Owners use a dedicated endpoint (GET /crm/v3/owners) instead of /crm/v3/objects/owners. The connector handles this automatically when object_type=owners is selected.
Endpoint Reference
crm_objects
Extract records from any CRM object type.
ParameterTypeRequiredDescription
object_typeselectYesOne of 27 CRM types + owners
max_itemsnumberNoMaximum records to extract (empty = all)
properties_filtertagsNoSpecific properties to fetch (empty = HubSpot default set)
API: GET /crm/v3/objects/{object_type}?properties={props}&limit=100&after={cursor}
Pagination: Cursor-based (paging.next.after)
Output: Raw JSON. Each record has id, createdAt, updatedAt, archived, and a nested properties dict containing all requested property values.
Properties behavior:
  • Empty filter: fetches ALL properties via GET /crm/v3/properties/{type} first, then requests all of them
  • With filter: requests only the specified properties
  • HubSpot returns all property values as strings (even numbers and dates)
Object TypeApprox. Default Properties
Contacts~370+ properties
Companies~250+ properties
Deals~200+ properties
associations
Extract relationships between CRM objects.
from_typeselectYesSource object type (14 options)
to_typeselectYesTarget object type (14 options)
max_itemsnumberNoMax source records to process
API: POST /crm/v4/associations/{from_type}/{to_type}/batch/read
Pagination: Cursor-based on source objects, batch POST for association lookup (max 1000 IDs per request)
Output: Raw JSON. Each result contains from and to objects with IDs and association metadata.
association_definitions
Get the available association types between two object types.
API: GET /crm/v4/associations/{from_type}/{to_type}/labels
Pagination: None (single GET)
Output: Raw JSON, association type definitions with category, type ID, and label.
pipelines
Extract pipeline definitions with their stages.
pipeline_object_typeselectYesdeals or tickets
API: GET /crm/v3/pipelines/{pipeline_object_type}
Pagination: None (single GET, returns all pipelines)
Output: Raw JSON. Each pipeline contains id, label, displayOrder, createdAt, updatedAt, and a nested stages array. The platform flattens stages into separate rows automatically.
pipeline_audit
Audit log for a specific pipeline.
pipeline_idtextYesPipeline ID (use pipelines endpoint to find IDs)
API: GET /crm/v3/pipelines/{object_type}/{pipeline_id}/audit
Output: Raw JSON, audit entries as returned by the API.
properties_meta
Extract the data dictionary (property schema) for an object type.
property_object_typeselectYesObject type (12 options)
API: GET /crm/v3/properties/{property_object_type}
Output: Raw JSON. Each property has name, label, type, fieldType, groupName, description, and more.
property_groups
Extract property groups for an object type.
API: GET /crm/v3/properties/{property_object_type}/groups
Output: Raw JSON, group definitions as returned by the API.
lists
Extract list and segment definitions.
max_itemsnumberNoMaximum lists to extract
API: GET /crm/v3/lists
Output: Raw JSON, list definitions as returned by the API.
list_memberships
Get member record IDs from a specific list.
list_idtextYesHubSpot List ID (ILS number, found in Contacts > Lists)
max_itemsnumberNoMaximum members to extract
API: GET /crm/v3/lists/{list_id}/memberships
Output: Raw JSON, membership records as returned by the API.
marketing_emails
Extract marketing email definitions with statistics.
max_itemsnumberNoMaximum emails to extract
API: GET /marketing/v3/emails
Output: Raw JSON, email campaign data with nested statistics, flattened by the platform.
forms
Extract form definitions.
max_itemsnumberNoMaximum forms to extract
API: GET /marketing/v3/forms
Output: Raw JSON, form definitions as returned by the API.
form_submissions
Extract submissions for a specific form.
form_idtextYesForm ID (find in Marketing > Forms > form details URL)
max_itemsnumberNoMaximum submissions to extract
API: GET /form-integrations/v1/submissions/forms/{form_id}
Pagination: Offset-based (v1 API, uses offset + hasMore, NOT cursor-based)
Output: Raw JSON, submission data as returned by the API.
conversations
Extract conversation threads (chat, email, bot).
max_itemsnumberNoMaximum threads to extract
API: GET /conversations/v3/conversations/threads
Output: Raw JSON, thread data as returned by the API.
Requires: Conversations scope + appropriate HubSpot plan
campaigns
Extract marketing campaign definitions.
max_itemsnumberNoMaximum campaigns to extract
API: GET /marketing/v3/campaigns
Output: Raw JSON, campaign data as returned by the API.
blog_posts
Extract CMS blog articles.
max_itemsnumberNoMaximum posts to extract
API: GET /cms/v3/blogs/posts
Output: Raw JSON, blog post data (title, content, author, publish date, etc.).
site_pages
Extract CMS website pages.
max_itemsnumberNoMaximum pages to extract
API: GET /cms/v3/pages/site-pages
Output: Raw JSON, page data as returned by the API.
landing_pages
Extract CMS landing pages.
API: GET /cms/v3/pages/landing-pages
workflows
Extract automation workflow definitions.
max_itemsnumberNoMaximum workflows to extract
API: GET /automation/v3/workflows
Pagination: None (single GET, data key is workflows, not results)
Output: Raw JSON, workflow definitions as returned by the API.
sequences
Extract sales sequence definitions.
max_itemsnumberNoMaximum sequences to extract
API: GET /automation/v4/sequences
Output: Raw JSON, sequence data as returned by the API.
Requires: Sales Hub Pro+
users
Extract account users.
max_itemsnumberNoMaximum users to extract
API: GET /settings/v3/users
Output: Raw JSON, user data as returned by the API.
imports
Extract CRM import history.
max_itemsnumberNoMaximum import records to extract
API: GET /crm/v3/imports
Output: Raw JSON, import records as returned by the API.
crm_schemas
Extract custom object schema definitions.
max_itemsnumberNoMaximum schemas to extract
API: GET /crm/v3/schemas
Output: Raw JSON, schema definitions as returned by the API.
custom_events
Extract behavioral events for a specific CRM record.
event_object_typeselectYesCRM object type (contacts, companies, deals, tickets)
event_object_idtextYesHubSpot record ID
max_itemsnumberNoMaximum events to extract
API: GET /events/v3/events?objectType={type}&objectId={id}
Pagination: Cursor-based (with extra_params)
Output: Raw JSON, event data as returned by the API.
Requires: Marketing Hub Enterprise
timeline_events
Extract timeline event templates for an integration app.
app_idtextYesHubSpot App ID (found in developer account)
API: GET /crm/v3/timeline/{app_id}/event-templates
Output: Raw JSON, event template data as returned by the API.
hubdb_tables
Extract HubDB table definitions.
max_itemsnumberNoMaximum tables to extract
API: GET /cms/v3/hubdb/tables
Output: Raw JSON, table definitions as returned by the API.
Scopes by Endpoint
CRM Objects
Object TypeRequired Scope
contactscrm.objects.contacts.read
companiescrm.objects.companies.read
dealscrm.objects.deals.read
ticketstickets
productse-commerce
line_itemscrm.objects.line_items.read
quotescrm.objects.quotes.read
calls, emails, meetings, notes, taskscrm.objects.contacts.read
communicationscrm.objects.contacts.read
feedback_submissionscrm.objects.feedback_submissions.read
leadscrm.objects.leads.read
invoicescrm.objects.invoices.read
subscriptionscrm.objects.subscriptions.read
goalscrm.objects.goals.read
orderscrm.objects.orders.read
paymentscrm.objects.payments.read
ownerscrm.objects.owners.read
Other Endpoints
EndpointRequired Scope
pipelines, pipeline_auditcrm.objects.deals.read or tickets (depends on pipeline_object_type)
properties_meta, property_groupsSame scope as the target object type
lists, list_membershipscrm.lists.read
marketing_emailscontent
forms, form_submissionsforms
associations, association_definitionsScopes for both the source and target object types
campaignscontent
blog_posts, site_pages, landing_pagescontent
For endpoints not listed above (workflows, sequences, users, imports, crm_schemas, conversations, custom_events, hubdb_tables, timeline_events), refer to HubSpot's scope reference for the authoritative scope name.
Pagination
The connector uses three pagination strategies depending on the endpoint:
Cursor-based (most endpoints)
GET /crm/v3/objects/contacts?limit=100&after=NTI1Cg==
Response:
  "results": [...],
  "paging": {
    "next": { "after": "NTI1Cg==" }
When paging.next.after is absent, all data has been fetched.
Offset-based (form submissions only)
GET /form-integrations/v1/submissions/forms/{id}?limit=50&offset=0
Response:
  "results": [...],
  "hasMore": true,
  "offset": 50
When hasMore is false, all data has been fetched.
No pagination (single GET)
Some endpoints return all data in a single response: pipelines, pipeline_audit, properties_meta, property_groups, association_definitions, workflows, timeline_events, crm_schemas.
Rate Limits
Limits by Plan
Refer to HubSpot's official rate limit documentation for current limits. Limits vary by plan and API endpoint.
Rate Limit Handling
The connector automatically handles 429 Too Many Requests responses:
  1. Reads the Retry-After header (seconds to wait)
  2. Falls back to 10 seconds if header is missing
  3. Retries the request after waiting
Output Format
Raw JSON (connector output)
The connector returns raw JSON from the HubSpot API via handle_api_extraction(data, limit, return_type). The data is a list of dicts, exactly as returned by the API.
Example CRM object (contacts):
  "id": "123",
  "createdAt": "2024-01-15T10:30:00.000Z",
  "updatedAt": "2024-03-20T14:22:00.000Z",
  "archived": false,
  "properties": {
    "email": "john@example.com",
    "firstname": "John",
    "lastname": "Doe",
    "createdate": "2024-01-15T10:30:00.000Z"
Flattened output (lakehouse)
The platform automatically flattens the raw JSON into a flat table. Nested keys become column names with underscores:
Raw JSON pathLakehouse column
idid
createdAtcreatedat
properties.emailproperties_email
properties.firstnameproperties_firstname
Column names are slugified: lowercase, dots/special chars replaced by underscores, must start with a letter or underscore.
Limitations
  • Property values are always strings, even numbers and dates. Cast them in your downstream processing.
  • Custom objects are not supported: the object_type parameter is a fixed select list of 27 standard CRM types + owners. Custom object types cannot be extracted with this connector.
  • Some object types require paid plans: invoices, subscriptions, and goals may require Sales Hub or Commerce Hub. Leads require Sales Hub Professional+. Commerce objects (carts, discounts, fees, taxes) require Commerce Hub. The API returns 403 if unavailable.
  • Form submissions use v1 API: the only endpoint still on the legacy v1 API. Uses offset pagination instead of cursor-based.
  • Behavioral events: require Marketing Hub Enterprise and a specific record ID (cannot bulk-extract all events).
  • Column names in lakehouse are slugified: properties.email becomes properties_email. This is handled by the platform, not the connector.
War diese Seite hilfreich?
