For AI agents: the complete documentation index is available at https://docs.ovhcloud.com/de/llms.txt, the full documentation bundle is available at https://docs.ovhcloud.com/de/llms-full.txt, and this page is available as Markdown at https://docs.ovhcloud.com/de/guides/public-cloud/data-platform/connectors-sources-odoo-technical-reference.md.
Odoo: Technical Reference
Als Markdown ansehen
This is the technical companion to the main Odoo connector documentation
This is the technical companion to the main Odoo connector documentation. It covers authentication internals, the full endpoint reference, pagination, rate limits, output format, the domain filter language, version compatibility, and limitations, everything needed to integrate the connector into a data pipeline.
Authentication
Protocol
The connector uses JSON-RPC 2.0 via POST {url}/jsonrpc. All requests go to a single endpoint with different JSON bodies.
Credentials
FieldRequiredDescription
urlYesOdoo instance URL (e.g., https://mycompany.odoo.com)
loginYesOdoo user email
api_keyYesAPI key generated from your Odoo profile
databaseNoAuto-detected from *.odoo.com subdomain. Required for self-hosted.
Auth Flow
  1. configure() calls authenticate(db, login, api_key) via JSON-RPC
  2. Returns uid (integer user ID)
  3. Every subsequent call passes (db, uid, api_key): stateless, no session cookie
Odoo Online Requirement
External API access requires the Custom plan on Odoo Online. Free and Standard plans do not include API access. See Odoo Pricing.
Architecture
The connector returns raw JSON from the Odoo JSON-RPC API. The platform takes over from there. It auto-discovers the schema from the JSON payload, flattens nested objects into columns, and stores the result in the lakehouse, queryable via Trino. Any new field that appears in your Odoo instance shows up automatically on the next extraction.
The connector itself is responsible for authentication (JSON-RPC authenticate to obtain a uid), endpoint routing, data extraction (a single search_read call shared by every model), schema introspection (fields_get), offset-based pagination, and rate-limit retries.
Because every Odoo model is reachable through the same search_read JSON-RPC call, the connector uses a single extraction path for all 26 predefined models, the custom_model endpoint, and any model surfaced through model_fields. Adding a new model means adding its name to the dropdown. No per-model code is needed.
Endpoint Reference
models
Extract records from any of the 26 predefined Odoo models.
ParameterTypeRequiredDescription
object_typeselectYesOdoo model (26 options)
fields_filtertagsNoSpecific fields to include (empty = all)
domain_filtertextNoOdoo domain filter as JSON (empty = all records)
max_itemsnumberNoMax records (empty = all)
API call: execute_kw(model, "search_read", [domain], {fields, limit, offset, order})
Pagination: Offset-based (limit=80, offset increments by 80)
Output: Raw JSON, list of dicts as returned by the Odoo API.
Predefined models (26):
DomainModels
Contactsres.partner
CRMcrm.lead, crm.stage, crm.team
Salessale.order, sale.order.line
Purchasespurchase.order, purchase.order.line
Invoicingaccount.move, account.move.line, account.journal
Productsproduct.template, product.product, product.category
Inventorystock.picking, stock.move, stock.warehouse, stock.location
HRhr.employee, hr.department
Projectsproject.project, project.task
Systemres.users, res.company, res.country, res.currency
custom_model
Extract records from any Odoo model not in the predefined list.
model_nametextYesFull technical model name (e.g., helpdesk.ticket)
domain_filtertextNoDomain filter as JSON
API call: Same as models: execute_kw(model_name, "search_read", ..)
Output: Raw JSON, same format as models.
Use cases: helpdesk.ticket, mrp.production, fleet.vehicle, event.event, or any custom model.
model_fields
Returns field definitions for any Odoo model (schema introspection).
model_nametextYesModel to inspect (e.g., res.partner)
API call: execute_kw(model_name, "fields_get", [], {attributes: [string, type, required, help, readonly, relation]})
Output: Raw JSON, list of dicts, each with field_name, string (label), type, required, help, readonly, relation (for relational fields).
Use case: Discover available fields and their types before setting up fields_filter on a models or custom_model extraction.
Pagination
The connector uses a single pagination strategy for all models:
Offset-based
Call 1: search_read(domain, {limit: 80, offset: 0, order: "id asc"})
Call 2: search_read(domain, {limit: 80, offset: 80, order: "id asc"})
Call 3: search_read(domain, {limit: 80, offset: 160, order: "id asc"})
...until returned records < 80
  • Page size: 80 (Odoo recommended)
  • Order: Always id asc for consistent pagination
  • Stop condition: Fewer records returned than the page size
  • max_items: When set, pagination stops as soon as enough records are collected, and the result is truncated to exactly max_items
Rate Limits
Refer to your Odoo instance documentation for exact limits.
EnvironmentApproximate Limit
Odoo Online (SaaS)Varies by plan, refer to Odoo documentation
Odoo.shVaries, refer to your instance configuration
Self-hostedDepends on server resources
The connector handles 429 Too Many Requests automatically: reads the Retry-After header and waits before retrying. Falls back to 10 seconds if the header is missing.
Output Format
Raw JSON (connector output)
The connector returns raw JSON from the Odoo API. Each record is a dict with all requested fields.
Example (res.partner):
  "id": 8,
  "name": "Acme Corp",
  "email": "contact@acme.com",
  "phone": "+33 1 23 45 67 89",
  "is_company": true,
  "country_id": [75, "France"],
  "category_id": [1, 3]
Relational fields
Odoo relational fields are returned as:
  • Many2one: [id, display_name] (e.g., "country_id": [75, "France"])
  • One2many / Many2many: list of IDs (e.g., "category_id": [1, 3])
The platform flattens these automatically.
Flattened output (lakehouse)
The platform flattens nested objects into columns with underscores:
Raw JSONLakehouse column
idid
namename
country_idcountry_id (flattened from array)
Domain Filter Reference
Odoo uses Polish (prefix) notation for domain filters. The connector accepts them as a JSON string.
Syntax
Each criterion is [field, operator, value]. Multiple criteria are AND-ed by default.
Operators
OperatorDescription
=, !=Equals / not equals
>, >=, <, <=Comparison
in, not inSet membership
like, ilikePattern match (ilike = case-insensitive)
not like, not ilikeNegated pattern match
=like, =ilikeSQL LIKE without auto-wrapping
child_of, parent_ofHierarchical relationships
Logical operators
OperatorArityDescription
&BinaryAND (implicit default)
|BinaryOR
!UnaryNOT
Examples
// Active companies
[["is_company", "=", true], ["active", "=", true]]
// Sales orders over 1000
[["state", "=", "sale"], ["amount_total", ">", 1000]]
// Leads OR opportunities
["|", ["type", "=", "lead"], ["type", "=", "opportunity"]]
// Invoices from 2024
[["invoice_date", ">=", "2024-01-01"], ["invoice_date", "<=", "2024-12-31"]]
Version Compatibility
Tested and supported on Odoo 14 through 19 (including Odoo Online saas~19.2).
Odoo VersionStatusAPI Key Support
14–18Fully supportedYes
19Fully supported (tested on saas~19.2)Yes
All 26 predefined models are stable across Odoo 14–19. If a model does not exist on your instance (depends on installed apps), use model_fields to check availability.
Limitations
  • No field hardcoding. The connector returns whatever the API provides. Field names and types depend on your Odoo version and installed modules.
  • Restricted fields. Some models have fields restricted to specific user groups (e.g., project.project.stage_id). Use fields_filter to exclude them, or grant the required group to your API user.
  • Binary fields. Fields like image_1920 return base64-encoded data, which can be very large. Use fields_filter to exclude image fields when not needed.
  • Odoo Online API access. Requires the Custom plan. Free and Standard plans block external API access.
  • No webhook/push extraction. The connector uses pull-based extraction only (JSON-RPC search_read).
  • One authentication method. API key only. OAuth2 is not supported.
War diese Seite hilfreich?
