For AI agents: the complete documentation index is available at https://docs.ovhcloud.com/de/llms.txt, the full documentation bundle is available at https://docs.ovhcloud.com/de/llms-full.txt, and this page is available as Markdown at https://docs.ovhcloud.com/de/guides/public-cloud/data-platform/connectors-sources-salesforce-technical-reference.md.
Salesforce: Technical Reference
Als Markdown ansehen
This is the technical companion to the main Salesforce connector documentation
This is the technical companion to the main Salesforce connector documentation. It covers authentication internals, endpoint behavior, pagination, rate limits, and the output format, everything needed to integrate the connector into a data pipeline.
1. Authentication: OAuth 2.0 Client Credentials Flow
Flow
The connector exchanges three credentials for a short-lived access token at the start of every run:
POST <instance_url>/services/oauth2/token
Content-Type: application/x-www-form-urlencoded
grant_type=client_credentials
&client_id=<Consumer Key>
&client_secret=<Consumer Secret>
Salesforce responds with an access_token, the canonical instance_url, and token_type: Bearer. The connector then uses Authorization: Bearer <token> on every subsequent request.
Tokens are not refreshed
Client Credentials Flow does not issue refresh tokens. The connector requests a fresh token on each extraction run, which fits within Salesforce's default access-token TTL (approximately 2 hours, see official docs for the value configured on your org).
Instance URL resolution
Whatever instance URL you type in the connector config, the token response returns the canonical URL for your org. The connector uses the response value for all REST calls, so you can provide either https://mycompany.my.salesforce.com or https://mycompany.develop.my.salesforce.com without issue.
Required OAuth scope
At minimum: Manage user data via APIs (api). Other scopes are not required for data extraction. Refer to the OAuth Tokens and Scopes official docs.
2. Architecture
  • Semi-structured pattern. Every endpoint returns raw JSON (list of dicts). The platform flattens nested fields (dot-notation) and infers the schema automatically. You don't declare columns anywhere.
  • Hybrid per-endpoint design. Data endpoints (sobject_records, soql_query, sosl_search) route through a shared SOQL pagination helper. Metadata endpoints (sobjects_list, sobject_describe, reports_list, limits) each call their dedicated REST resource.
  • Describe-then-query for default fields. When sobject_records is used without fields_filter, the connector first fetches the sObject's describe to collect all queryable field names, then builds a SOQL SELECT listing them explicitly. Salesforce SOQL has no SELECT *: explicit fields are always required.
  • Input normalization. SOQL/SOSL inputs are trimmed of leading/trailing whitespace and any trailing ; (Salesforce doesn't use statement terminators). The where_clause field accepts input with or without a leading WHERE keyword. The connector strips it if present before prepending its own.
3. Endpoint reference
All data endpoints return a list of JSON objects. Each object from /query includes an attributes sub-dict ({"type": "<sObject>", "url": "/services/data/v60.0/sobjects/<sObject>/<Id>"}) alongside the requested fields.
sobject_records
Extract records from a standard or custom sObject via SOQL.
ParameterTypeRequiredDescription
sobject_nametextyesAPI name of the sObject (e.g. Account, Contact, MyObject__c)
fields_filtertagsnoExplicit list of field API names. Empty → all queryable fields, discovered via describe
where_clausetextareanoSOQL WHERE expression, without the WHERE keyword (optional, leading WHERE is stripped)
max_itemsnumbernoHard cap on returned records
  • API call: GET /services/data/v60.0/query?q=SELECT <fields> FROM <sobject_name> [WHERE <where_clause>]
  • Pagination: SOQL nextRecordsUrl (cursor-based, see section 4)
  • Output: Raw SOQL response records.
soql_query
Freeform SOQL for advanced use cases (sub-queries, aggregates, joins).
soqltextareayesSOQL statement. Multi-line supported
  • API call: GET /services/data/v60.0/query?q=<soql>
  • Output: Raw SOQL response records. Structure depends on the query.
Salesforce Object Search Language: full-text search across multiple sObjects.
sosltextareayesSOSL statement (e.g. FIND {Acme} IN NAME FIELDS RETURNING Account(Id, Name))
  • API call: GET /services/data/v60.0/search?q=<sosl>
  • Pagination: Single-page. SOSL returns a bounded result set, typically capped server-side at 2000 records.
  • Output: Each record in searchRecords includes the attributes.type field identifying its sObject.
sobjects_list
The full catalog of sObjects available to the Run As user.
  • API call: GET /services/data/v60.0/sobjects
  • Output: One record per sObject with metadata (name, label, custom, queryable, createable, etc.).
sobject_describe
Full schema (fields, types, relationships, picklist values) for one sObject.
  • API call: GET /services/data/v60.0/sobjects/<name>/describe
  • Pagination: Single record returned (one-row table).
  • Output: The entire describe object from Salesforce, deeply nested, includes fields, childRelationships, etc. The platform flattens it to dot-notation columns.
reports_list
List of reports stored in your org.
  • API call: GET /services/data/v60.0/analytics/reports
  • Pagination: Single-page. Returns at most the first few hundred reports.
  • Output: One record per report (Id, Name, DeveloperName, FolderName, etc.). Reports themselves are not executed.
limits
Org-level API usage and quotas.
  • API call: GET /services/data/v60.0/limits
  • Pagination: Single-page (the payload is one JSON object describing dozens of limits).
  • Output: The connector reshapes the response into a list of records, one per named limit, with the original keys (Max, Remaining) preserved.
4. Pagination
SOQL-based endpoints (sobject_records, soql_query) use Salesforce's cursor-based pagination:
  • First response includes totalSize, done: false, records, and nextRecordsUrl (a path like /services/data/v60.0/query/01g...-2000).
  • The connector follows nextRecordsUrl until done: true or max_items is reached.
  • Default page size is 2000 records (server-side default).
Non-SOQL endpoints (sosl_search, sobjects_list, sobject_describe, reports_list, limits) do not paginate in this version.
5. Rate limits & error handling
Salesforce limits
  • Daily API Requests: org-wide soft quota, varies by edition (e.g. 100,000/day on Enterprise base, higher on Unlimited, generous on Developer Edition). See the limits endpoint for the exact current value on your org.
  • Concurrent calls: 5 on Developer Edition, 25 on Enterprise+. Each request times out at 10 minutes server-side.
See API Request Limits and Allocations for current numbers.
What the connector does
  • HTTP 429: rare on Salesforce REST but handled: the connector honors the Retry-After header and retries the same request.
  • HTTP 4xx other: surfaced immediately as an extraction failure with the Salesforce error message in logs. The connector does not catch permission errors; if the Run As user can't see a field or sObject, the extraction fails and the error is visible.
  • HTTP 5xx: same as 4xx, surfaced immediately. Transient server errors will need a manual re-run.
Common Salesforce error codes
Error codeMeaning
INVALID_SESSION_IDAccess token expired, re-run extracts a fresh token
MALFORMED_QUERYSOQL/SOSL syntax error, check the query text
INVALID_TYPEsobject_name doesn't exist or isn't accessible
INVALID_FIELDA field listed in fields_filter isn't visible to the Run As user
REQUEST_LIMIT_EXCEEDEDDaily API quota hit, wait or increase the org allocation
INSUFFICIENT_ACCESSRun As user lacks object/field-level permission
6. Output format
Every endpoint returns raw JSON. The platform automatically:
  • Flattens nested dicts to dot-notation columns (e.g. attributes.type, attributes.url).
  • Infers the schema from the first batch and extends it if later batches introduce new fields.
  • Stores the result in the lakehouse under your dataset as a queryable table.
For sobject_records and soql_query, each record contains the fields you selected plus the attributes sub-object. For metadata endpoints (sobject_describe, sobjects_list, limits), the payload is the API response reshaped into one-or-more records.
Column names reflect Salesforce's API field casing (PascalCase for standards: Id, Name, CreatedDate. Custom fields preserve whatever casing you gave them, e.g. MyField__c).
7. Limitations
  • Salesforce REST API v60.0 is hardcoded. Newer versions (Spring '26 is v66.0 at time of writing) add features not surfaced as dedicated endpoints; they remain accessible via soql_query for anything queryable.
  • No write operations (no create/update/delete).
  • No Bulk API 2.0 support: Salesforce REST queries, while paginated, are less efficient than Bulk for multi-million-row extractions.
  • No Streaming / Platform Events / Pub/Sub API: batch-only connector.
  • Reports are listed, not executed. Report execution via /analytics/reports/<id>/executeAsync is out of scope in this version.
  • Compound fields (address, location) excluded from default field discovery. When fields_filter is empty, the connector skips these types because they require sub-field queries. Use an explicit fields_filter listing the sub-fields (e.g. BillingStreet, BillingCity, BillingCountry) to extract them.
  • SOQL FIELDS(ALL) not used. Salesforce's FIELDS(ALL) syntax requires a LIMIT 200 and has other restrictions; the connector prefers the describe-then-query approach for predictability at scale.
War diese Seite hilfreich?
