AI Endpoints - Sorties structurées
Introduction
Structured Output is a powerful feature that allows you to enforce specific formats for the responses from AI models. By using the response_format parameter in your API calls, you can define how you want the output to be structured, ensuring consistency and ease of integration with your applications. This is particularly useful when you need the AI model to return data in a specific JSON format. The JSON schema specification can be used to describe what data structure should the output adhere to, and the AI model will generate responses that match it. This feature allows for seamless integration of AI-generated data into your applications, enabling you to build robust and consistent workflows.
This documentation provides an overview on how to use structured outputs with the various AI models offered on AI Endpoints.
The examples provided in this guide will be using the Llama 3.3 70b model.
Visit our Catalog to find out which models are compatible with Structured Output.
The output formats managed by each model are defined in the Response Format section:
Model Specs
The examples provided during this guide can be used with one of the following environments:
Python
A Python environment with the openai client and the pydantic library installed.
pip install openai pydantic
Javascript
A Node.js environment with the request library. Request can be installed using NPM:
npm install request
Curl
A standard terminal, with curl installed on the system.
Authentication & rate limiting
Most of the examples provided in this guide use anonymous authentication, which makes it simpler to use but may cause rate limiting issues. If you wish to enable authentication using your own token, simply specify your API key within the requests.
Follow the instructions in the AI Endpoints - Getting Started guide for more information on authentication.
The response_format parameter of the Chat Completion API allows us to enable and configure the Structured Output features.
Models that support structured output can manage the three following modes:
  • {"type": "text"} The default textual format. This is the same as specifying no response_format.
  • {"type": "json_object"} The JSON object format is a legacy format that was introduced with the first iteration of Structured Outputs. This mode is non-deterministic and allows the model to output a JSON object without strict validation.
  • {"type": "json_schema", "json_schema": .. } JSON schema is a very powerful tool used to specify and validate a JSON data structure. This latest kind of response_format allows us to enforce custom output formats in LLM outputs using this specification and ensure consistency and interoperability with a variety of platforms and applications.
When using the JSON schema mode, outputs are deterministic and will always adhere to the schema specified.
We recommend using JSON schema over JSON object whenever possible.
JSON schema
The following code samples provide a simple example on how to specify a JSON schema, using the response_format parameter.
Python
Curl
Javascript
For this example, we can use the openai Python library, combined with pydantic for powerful JSON schema management.
from pydantic import BaseModel
import openai
import os
# Define the prompts
messages = [
    { "content": "You are a helpful assistant that help users rank different things. You always answer in JSON format.", "role": "system" },
    { "content": "What are the top 3 most popular programming languages ?", "role": "user" }
# Define the data model
class Language(BaseModel):
    website: str
    ranking: int
class LanguageRankings(BaseModel):
    languages: list[Language]
# Initialise the client
api_key = os.environ['AI_ENDPOINT_API_KEY'] # Assuming your API key is available in this environment variable (export AI_ENDPOINT_API_KEY='your_api_key')
openai_client = openai.OpenAI(
    base_url='https://oai.endpoints.kepler.ai.cloud.ovh.net/v1',
    api_key=api_key
# Optionally, print the json schema infered from the pydantic model
print(f'JSON schema: {LanguageRankings.model_json_schema()}')
# Run the query
response = openai_client.beta.chat.completions.parse(
    model='Meta-Llama-3_3-70B-Instruct',
    messages=messages,
    response_format=LanguageRankings,
    temperature=0 # Ensure deterministic output for this guide's purpose
# Print the parsed response
language_rankings = response.choices[0].message.parsed
for language in language_rankings.languages:
    print(f"{language.name} is the n°{language.ranking} language ({language.website})")
Output:
JSON schema: {'$defs': {'Language': {'properties': {'name': {'title': 'Name', 'type': 'string'}, 'website': {'title': 'Website', 'type': 'string'}, 'ranking': {'title': 'Ranking', 'type': 'integer'}}, 'required': ['name', 'website', 'ranking'], 'title': 'Language', 'type': 'object'}}, 'properties': {'languages': {'items': {'$ref': '#/$defs/Language'}, 'title': 'Languages', 'type': 'array'}}, 'required': ['languages'], 'title': 'LanguageRankings', 'type': 'object'}
JavaScript is the n°1 language (https://www.javascript.com/)
Python is the n°2 language (https://www.python.org/)
Java is the n°3 language (https://www.java.com/)
NOTE: this example is using openai_client.beta.chat.completions.parse to leverage automatic parsing with pydantic, but it is also possible to use openai_client.chat.completions.create, by using the response_format parameter and specifying the JSON schema manually.
JSON object
The following code samples provide a simple example on how to use the legacy JSON object mode, using the response_format parameter. Note that when using the JSON object mode, we cannot explicitly specify the schema of the output.
Python
Curl
Javascript
import json
import openai
import os
messages = [
    api_key=api_key
# Run the query
response = openai_client.chat.completions.create(
    messages=messages,
    response_format={
        "type": "json_object",
# Print the response
output = json.loads(response.choices[0].message.content)
print(json.dumps(output, indent=2))
Output:
  "rank": [
      "position": 1,
      "language": "JavaScript",
      "popularity": "94.5%"
      "position": 2,
      "language": "HTML/CSS",
      "popularity": "83.6%"
      "position": 3,
      "language": "Python",
      "popularity": "78.9%"
Tips and best practices
This section contains additional tips that may improve the performance of Structured Output queries.
Streaming
All kinds of response_format are compatible with streaming. To enable streaming, simply use "streaming": true in your request's body and process the stream accordingly.
Example with python:
import openai
import os
messages = [
    website: str
    ranking: int
    api_key=api_key
# Run the query
with openai_client.beta.chat.completions.stream(
    messages=messages,
    temperature=0,
) as stream:
    for event in stream:
        if event.type == "response.refusal.delta":
            print(event.delta, end="")
        elif event.type == "response.output_text.delta":
        elif event.type == "response.error":
            print(event.error, end="")
        elif event.type == "response.completed":
            print("Completed")
        elif event.type == "chunk":
            if len(event.chunk.choices):
                print(event.chunk.choices[0].delta.content, end="")
    response = stream.get_final_completion()
Streamed output response:
{"languages": [
    {"name": "JavaScript", "ranking": 1, "website": "https://www.javascript.com/"},
    {"name": "Python", "ranking": 2, "website": "https://www.python.org/"},
    {"name": "Java", "ranking": 3, "website": "https://www.java.com/"}
Schema definition
Some considerations about the JSON schema definition:
  • Structured output currently supports a subset of the JSON schema specification. Some features may not be compatible.
  • The models will generate the output following alphabetical order of the JSON schema keys. It may be useful to rename your fields to enforce a specific order during generation.
  • To avoid divergence, we recommend setting additional properties to false and explicity setting the required fields.
Don't hesitate to experiment with different variations of your JSON schemas to reach the best performance!
Prompting & additional parameters
Some additional considerations regarding prompts and model parameters:
  • Even though the response_format can be used to enable structured outputs, models can generally perform better when asked to produce json outputs within the prompt (messages field).
  • Most models tend to perform better when using lower temperature for structured outputs.
  • Some model providers may recommend specific system prompts and parameters to use for structured outputs and function calling. Don't hesitate to visit the model pages to dive deeper into model specifics (An example for Llama 3.3 on HuggingFace).
Conclusion
In this guide, we have explained how to use Structured Output with the AI Endpoints models. We have provided a comprehensive overview of the feature which can help you perfect your integration of LLM for your own application.
To discover how to build complete and powerful applications using AI Endpoints, explore our dedicated AI Endpoints guides.
Feedback
