AI Endpoints - Caractéristiques, capacités et limites (EN)
AI Endpoints is covered by the OVHcloud AI Endpoints Conditions and the OVHcloud Public Cloud Special Conditions.
Introduction
This page provides the technical features, capabilities and limitations of AI Endpoints.
Features
Available features
Planned Features
For upcoming developments, check our Public Cloud Roadmap to stay informed about new features and model updates.
Capabilities
Compatibility with OpenAI API
AI Endpoints is designed to be compatible with the OpenAI API, making it easy to integrate with existing applications and workflows. This compatibility means that you can take advantage of AI capabilities without having to make major changes to your existing technology stack, allowing you to get up and running quickly and easily.
Flexible usage
AI Endpoints' APIs are language-agnostic. It enables developers to use any programming language or technology of their choice when working with our APIs, providing them with the freedom to build and integrate AI capabilities according to their requirements and preferences.
Limitations
Model rate limit
When using AI Endpoints, the following rate limits apply:
- Anonymous: 2 requests per minute, per IP and per model.
- Authenticated with an API access key: 400 requests per minute, per Public Cloud project and per model.
If you exceed this limit, a 429 error code will be returned.
Payload size limits
To ensure security and stability, AI Endpoints APIs enforce default request payload size limits:
Most endpoints are limited to 2 MB per request body. This applies to common input types such as String and Json parameters. Some endpoints, like those handling media files, are specifically configured to accept larger payloads due to their use cases.
Visual Language Models (VLM) are limited to 10 MB per request body. Audio transcription endpoints can handle larger audio files, but are limited by audio file size and duration. The specific limits of these endpoints are indicated in their respective model documentation.
No usage limit
As of now, the AI Endpoints platform does not impose any usage limits for API requests, apart from the rate and payload size limiting.
However, we are considering introducing a usage limit feature in the future. This feature will allow you to set a limit on the number of tokens, characters, seconds of audio consumed, depending on your usage, providing better control and management over AI Endpoints consumption.
Going further
To discover how to build complete and powerful applications using AI Endpoints, explore our dedicated AI Endpoints guides.
Feedback
Please feel free to send us your questions, feedback, and suggestions regarding AI Endpoints:
- In the #ai-endpoints channel of the OVHcloud Discord server, where you can engage with the community and OVHcloud team members.
