Shopify: Technical Reference
This is the technical companion to the main Shopify connector documentation
This is the technical companion to the main Shopify connector documentation. It covers authentication internals, the full endpoint reference, pagination, rate limits, output format, and limitations, everything needed to integrate the connector into a data pipeline.
Authentication
Supported Modes
The connector supports two interchangeable authentication modes that both end up sending an X-Shopify-Access-Token header on every API request.
If access_token is filled, it takes priority. The OAuth exchange is skipped.
Token Formats
Both prefixes are valid in the Access Token field and are used identically by the connector.
Deprecated authentication methods
Custom App Approval
For Customer / Order / DraftOrder / AbandonedCheckout / FulfillmentOrder data, Shopify requires Protected Customer Data approval at the app level. On a development store this is granted instantly when the merchant ticks the relevant boxes in the Dev Dashboard. On production stores distributed via the App Store, Shopify reviews the request manually.
When the approval is missing, the API returns ACCESS_DENIED errors on the affected fields. The connector treats these as expected and returns whatever data was successfully fetched (with the restricted fields blanked out).
Architecture
The connector returns raw JSON from the Shopify GraphQL API. The platform takes over from there. It auto-discovers the schema from the JSON payload, flattens nested objects into dot-notation columns (slugified to lowercase with underscores), and stores the result in the lakehouse, queryable via Trino. Any new field Shopify adds to a node appears automatically on the next extraction.
The connector itself is responsible for:
API Version
All requests target the 2026-04 version of the Shopify Admin GraphQL API. Update Shopify's release notes before pinning to a newer version, schema changes can rename fields or change types.
Endpoint Reference
Every paginated endpoint shares the same call shape:
The connector iterates pages until pageInfo.hasNextPage == false or the user-specified max_items cap is reached.
For each endpoint below, "Output" is Raw JSON: the full GraphQL node object, with nested fields preserved. The platform flattens it downstream.
products
Root field: products(first, after, sortKey: CREATED_AT)
Default fields: id, handle, title, description, vendor, productType, status, tags, timestamps, totalInventory, tracksInventory, featuredImage, options, seo, onlineStoreUrl, priceRangeV2.
product_variants
Root field: productVariants(first, after): top-level since API 2022-07; no parent product ID required.
Default fields: id, sku, title, position, price, compareAtPrice, barcode, taxable, inventoryQuantity, availableForSale, timestamps, selectedOptions, parent product ref, image.
collections
Root field: collections(first, after): unified view of manual + smart collections.
Default fields: id, handle, title, description, updatedAt, sortOrder, productsCount, seo, image.
customers
Root field: customers(first, after)
Default fields: id, firstName, lastName, email, phone, state, note, tags, timestamps, verifiedEmail, numberOfOrders, amountSpent, defaultAddress, lifetimeDuration.
PII fields (firstName, lastName, email, phone, defaultAddress.zip) require Protected Customer Data approval. Without it the rows still come through with those fields blanked out.
customer_segment_members
Root field: customerSegmentMembers(first, after, segmentId: $segment_id)
Use the segments endpoint first to discover segment IDs.
orders
Root field: orders(first, after, query: $query_filter, sortKey: CREATED_AT)
query_filter accepts Shopify search syntax (e.g. created_at:>=2026-01-01, financial_status:paid).
Default fields: id, name, legacyResourceId, lifecycle timestamps, displayFinancialStatus, displayFulfillmentStatus, money sets (totalPrice, subtotalPrice, totalTax, totalDiscounts, totalRefunded, totalShippingPrice), customer, addresses, channelInformation.
draft_orders
Root field: draftOrders(first, after)
Default fields: id, name, status, email, note2, timestamps, money sets, customer, shippingAddress.
abandoned_checkouts
Root field: abandonedCheckouts(first, after)
Default fields: id, name, abandonedCheckoutUrl, timestamps, money sets, customer.
fulfillment_orders
Root field: fulfillmentOrders(first, after)
Default fields: id, status, requestStatus, timestamps, destination (address fields), assignedLocation, parent order.
tender_transactions
Root field: tenderTransactions(first, after)
Default fields: id, paymentMethod, processedAt, remoteReference, test, amount, parent order, user.
locations
Root field: locations(first, after)
Default fields: id, name, isActive, timestamps, fulfillsOnlineOrders, shipsInventory, legacyResourceId, address.
inventory_items
Root field: inventoryItems(first, after)
Default fields: id, sku, tracked, requiresShipping, timestamps, countryCodeOfOrigin, harmonizedSystemCode, unitCost, parent variant + product.
segments
Root field: segments(first, after)
Default fields: id, name, query (segment definition expression), creationDate, lastEditDate.
companies
Root field: companies(first, after): B2B only; returns empty if B2B is not enabled on the store.
Default fields: id, name, externalId, note, timestamps, locationsCount, ordersCount, totalSpent.
company_locations
Root field: companyLocations(first, after): B2B only.
Default fields: id, name, externalId, note, timestamps, addresses, parent company.
price_lists
Root field: priceLists(first, after): B2B / wholesale.
Default fields: id, name, currency, parent.adjustment, linked catalog.
catalogs
Root field: catalogs(first, after): B2B catalog assignments.
Default fields: id, title, status, linked priceList.
markets
Root field: markets(first, after): multi-region configuration.
Default fields: id, name, handle, enabled, primary, webPresence.rootUrls, currencySettings.baseCurrency.
discount_nodes
Root field: discountNodes(first, after): union of automatic + code + manual discounts.
Default fields: id, plus a typed discount payload using inline fragments for DiscountAutomaticBasic, DiscountAutomaticBxgy, DiscountCodeBasic, DiscountCodeBxgy, DiscountCodeFreeShipping, DiscountAutomaticFreeShipping. Each variant exposes title, status, startsAt, endsAt, usage counts.
code_discount_nodes
Root field: codeDiscountNodes(first, after): code discounts only.
Same field shape as discount_nodes, restricted to the DiscountCode* types.
gift_cards
Root field: giftCards(first, after): Shopify Plus only.
Default fields: id, enabled, expiresOn, timestamps, lastCharacters, note, balance, initialValue, owning customer.
selling_plan_groups
Root field: sellingPlanGroups(first, after): subscription plans.
Default fields: id, name, description, createdAt, merchantCode, appId, summary, productsCount, options.
marketing_events
Root field: marketingEvents(first, after): campaign tracking.
Default fields: id, type, remoteId, startedAt, endedAt, manageUrl, previewUrl, UTM fields, owning app.
publications
Root field: publications(first, after): sales-channel publications.
Default fields: id, name, supportsFuturePublishing, owning app.
payouts / disputes / balance_transactions
Root path: shopifyPaymentsAccount.{payouts | disputes | balanceTransactions}(first, after). Shopify Payments must be enabled on the store. The connector returns an empty list (with a warning) when shopifyPaymentsAccount is null.
Default fields (payouts): id, status, issuedAt, net, summary breakdown.
Default fields (disputes): id, status, initiatedAt, amount, reasonDetails.
Default fields (balance_transactions): id, type, transactionDate, test, amount, fee, net.
metaobjects
Root field: metaobjects(first, after, type: $metaobject_type)
Use the metaobject_definitions endpoint first to list the available types.
Default fields: id, handle, type, displayName, updatedAt, capabilities.publishable.status, fields[].{key, value, type, jsonValue}.
Root field: metaobjectDefinitions(first, after)
Default fields: id, type, name, displayNameKey, description, nested fieldDefinitions.
metafield_definitions
Root field: metafieldDefinitions(first, after, ownerType: $owner_type)
Default fields: id, namespace, key, name, description, ownerType, type.name, pinnedPosition.
articles / blogs / pages / url_redirects / files
Standard paginated content endpoints. Each returns the typed node object, see the Shopify GraphQL reference for the exact field shape per type. The connector requests a sensible default field subset per endpoint (handle, title, body/summary, timestamps, publication status, ..).
For files, the query uses inline fragments for MediaImage, Video, and GenericFile, so the output includes a media-type-specific payload alongside id, alt, createdAt, fileStatus.
events
Root field: events(first, after, sortKey: CREATED_AT, reverse: true): shop audit log.
Default fields: id, message, createdAt, appTitle, attributeToApp, attributeToUser, criticalAlert.
staff_members / delivery_profiles / fulfillment_services
Standard endpoints with a max_items parameter. fulfillment_services is unusual. The data is nested under shop.fulfillmentServices and is returned as a list (not paginated). The connector handles the special path automatically.
shop
No parameters. Returns a one-element list with the store's metadata, id, name, domain, currency, timezone, plan, billing address, primary domain, feature flags, timestamps. Useful as a small reference table.
custom_query
Run any GraphQL query against the Admin API. Constraints:
- The query must declare
$first: Int!and$after: Stringas variables. - It must paginate one connection with
pageInfo { hasNextPage endCursor }. - Either provide
connection_path(dot-path to the connection from the data root, e.g.products,shop.metafields) or let the connector auto-detect the firstedges/pageInfoconnection in the response.
The connector substitutes $first (defaults to 250 or max_items when set) and $after (cursor from the previous page), then loops until pageInfo.hasNextPage is false.
variables lets you pass additional parameters used by your query (e.g. {"query": "tag:vip"} for a customer search filter). $first / $after are reserved.
Validation runs at extract time, invalid queries (missing variables) raise a clear error before the first HTTP call.
Pagination
All paginated endpoints use cursor-based pagination (Relay-style connections). The connector loops:
With first: 100 (default page size, capped at 250) and after: <previous endCursor>. The loop ends when hasNextPage == false or the user-specified max_items is reached.
Single-object endpoints (shop) and the nested list fulfillment_services skip pagination. The connector wraps the response in a one-element list.
Rate Limits
The Shopify Admin GraphQL API uses cost-based rate limiting (not requests-per-second). Every query has a point cost computed from its connection sizes; each store has a per-app bucket that refills at a fixed rate.
Refer to Shopify's official rate-limit documentation for current details.
Throttle Handling
The connector handles throttling in three ways:
- Pre-emptive sleep: after every response, it inspects
extensions.cost.throttleStatus. If the next page's cost would exceed the currently available budget, it sleeps for the time needed to refill. - GraphQL
THROTTLEDerrors: Shopify sometimes returns HTTP 200 with aTHROTTLEDerror in the body. The connector retries after a short back-off. - HTTP 429: rare, but handled with
Retry-After. The connector retries up to 5 times before raising.
Output Format
Raw JSON
The connector returns the contents of edges[].node as a list of dicts, exactly as Shopify GraphQL returned them. Nested objects (addresses, money sets, child arrays) are preserved.
Example product node (truncated):
Flattened in the lakehouse
The platform automatically flattens nested objects into dot-notation columns, then slugifies them:
List-of-object fields (e.g. tags, options) are exploded automatically, one row per list element.
Limitations
- GIDs are strings, not integers. Shopify identifiers come as
gid://shopify/Resource/12345: keep them as strings in your downstream queries. - No bulk operations. Very large extractions (millions of records) page synchronously through the GraphQL API. For multi-million-row stores, write a
custom_queryagainstbulkOperationRunQueryinstead, or extract incrementally with a date filter (query_filter). - Shopify Payments endpoints require enrollment.
payouts,disputes,balance_transactionsreturn empty lists if Shopify Payments isn't activated on the store. - Protected Customer Data field-level approval. Without it, customer / order rows return with PII fields (firstName, lastName, email, phone, zip) blanked out, but the rows themselves are returned. Approve the relevant data categories in the Dev Dashboard to get full PII.
- Sub-resources require
custom_query. Per-order transactions / refunds / fulfillments and per-product metafields aren't dedicated endpoints. They are accessible viacustom_queryif you write a nested GraphQL. - B2B endpoints return empty without B2B.
companies,company_locations,catalogs,price_listsreturn[]on stores without B2B enabled. No error, just empty. gift_cardsis Shopify Plus only. Lower plans receiveACCESS_DENIEDand the connector returns an empty list.- Field set is fixed per endpoint. Each built-in endpoint has a default field selection. To customize fields (more or fewer), use
custom_query. - Shopify GraphQL changelog. The connector is pinned to API version
2026-04. Field renames or removals in newer versions are not picked up automatically, review Shopify's release notes before bumping the version.
