AI Deploy - Features, Capabilities and Limitations
This page provides the technical capabilities and limitations of the Public Cloud AI Deploy offer.
Features
Available features
AI Deploy allows you to deploy your AI applications and models with compute resources (CPUs, GPUs) and high availability.
FeatureDetails
AI environments
Preinstalled Machine Learning environmentsAI Deploy comes with a generic Python environment (Conda) or pre-installed ones, such as Pytorch, Tensorflow, FastAI, HuggingFace and more.
Easy customizationAI Deploy allows installation of almost any Conda or Pip packages. You can easily customize your environment to suit your needs. It also allows you to use your own environment by specifying your Docker image.
Management
Multiple ways to manage your deployed appsYou can manage your AI Deploy apps through the OVHcloud Control Panel, API or CLI. Depending on your needs, you can easily automate their creation and deletion as well.
Easy start and StopYou can start and stop an app in one click.
Check the logs of your appYou can also check the logs of your deployed app through the OVHcloud Control Panel, API or CLI.
Compute resources
Guaranteed compute resourcesSelect the amount of CPUs or GPUs required during the creation of the AI Deploy app. Once launched, you will keep these resources as long as your app is running.
Background executionYour tasks can be executed in the background, meaning that closing your Web browser will have no effect on your work.
No maximum runtimeYour tasks can last as long as your app is running.
Monitoring toolsEach AI Deploy app comes with a native Grafana dashboard, allowing you to keep track and monitor your CPU, GPU, RAM and storage resources.
Storage
Fast and flexible storageEach AI Deploy service comes with local storage, but also the ability to attach remote storage from Object Storage. From a few GiB to multiple TiB, we push your data near our compute power on fast SSD storage for better performances.
Git repositories importationDuring the creation of your AI Deploy app, you can specify one or multiple Git repositories to download inside your app environment.
Security
Open or restricted authenticationDuring the creation of your AI Deploy app, you can either select Public Access, allowing anyone to access your application, or Restricted Access, allowing access via security tokens or credentials.
European valuesWe respect your privacy and will never use your personal data for our internal purposes.
Availability and billing
Easy billingYou only pay for what you consume, billed per minute.
Available in many countriesAI Deploy requires an OVHcloud account. We currently accept dozens of countries. Once created, you will have access to the whole set of features.
Logs and Monitoring tools
Command line interface (CLI)
AI Deploy is compliant with the OVHcloud AI CLI. Discover how to install the OVHcloud AI CLI.
Logs
To check the logs of your app, you can do it via the ovhai CLI using the following command:
ovhai app logs <app-id>
Monitoring tools
To see information of your app, you can do so with the ovhai CLI using the command above:
ovhai app get <app-id>
You can then access your metrics through the Monitoring Url.
You are also able to check it from the OVHcloud Control Panel in your app information by clicking the Go to Graph Dashboard button.
API management
API endpoints to manage your AI Deploy apps can be found here:
Planned features
We continuously improve our offers. You can follow, vote and submit ideas to add to our roadmap at https://github.com/ovh/public-cloud-roadmap/projects/4.
Capabilities and limitations
Supported regions and multi-AZ deployments
AI Deploy can be used from any country in the world, as long as you have an OVHcloud account. Physically, two datacenters are available:
  • BHS (Beauharnois, Canada, America)
  • GRA (Gravelines, France, Europe)
Entire AI Deploy instances have to be in the same region. Multi-AZ is currently not supported.
Attached resources
Compute resources
Replica type
You can either choose the number of GPUs or CPUs for an AI Deploy app, not both. By default, an app uses one CPU instance. The memory resource is not customisable.
Available replica ranges
If you choose GPU:
  • CPU, memory and local storage resources are not customisable but scaled linearly with each additional GPU.
If you choose CPU:
  • Memory and local storage resource is not customisable but scaled linearly with each additional CPU.
The maximum amount of CPU/GPU, memory per CPU/GPU and local storage is available on the OVHcloud website, Control Panel and the ovhai CLI.
ovhai capabilities flavor list
For your information, the current limits are:
  • CPU: 12 per app.
  • GPU: 4 per app.
Available hardware for AI Deploy
Currently, we provide:
Scaling
AI Deploy offers the possibility to choose between two scaling strategies: static or automatic.
If you choose static scaling:
  • You can go from 1 to 10 replicas.
If you choose autoscaling:
  • You can choose both the minimum number of replicas (1 by default) and the maximum number of replicas.
  • You can define the metric monitored that will act as a trigger for autoscaling: CPU or RAM.
  • You can choose the threshold for the percentage of average use: integer between 1 and 100%.
Available storage
Local storage
Each AI Deploy app comes with a local storage space, which is ephemeral. When you delete your app, this storage space is also deleted. This storage space depends on the selected instances during AI Deploy app deployment. Please refer to the compute resources section for more information.
Local storage is limited and not the recommended way to handle data, see the OVHcloud documentation on data for more information.
Attached storage
You can attach data volumes from Public Cloud Object Storage. The Object Storage bucket should be in the same region as your AI Deploy app. Attached storage allows you to work on several TB of data, while being persistent when you delete your AI Deploy app.
Maximum execution time
There is no duration limitation on AI Deploy apps execution.
Environment customization & Permitted deployment
Each environment can be customized directly with PIP or CONDA (we support almost any package and library).
AI Deploy authorizes the deployment of your own Docker images, and of applications from the OVHcloud portfolio.
Docker images can be hosted in a public or private registry.
The use of docker-compose is not possible.
Please be aware that images need to be built with an AMD architecture.
High-availability
Your application is deployed simultaneously on the amount of selected instances. To benefit from high-availability, a minimum of two instances is required. In case of instance failure, a new one is automatically created.
Rolling upgrade
You can update the Docker image of your application to provide an updated version of your service. Updates are incremental and will not cause any downtime. Your current configuration will also be preserved, such as your HTTP endpoint and deployment policy. There is no need to stop and restart the application for the image update to take effect.
Network
  • Public networking can be used for all the AI Tools.
  • Private networking (vRack) is not supported.
  • Ports: you can map your AI Deploy app to only one port. Default port is 8080.
  • Ingress and Egress traffic are included in the service plans and not metered.
Quotas per Public Cloud project
Each Public Cloud project grants a customer by default a maximum of 4 GPUs used simultaneously. Reach out to our support if you need to increase this limitation.
Browse the full AI Deploy documentation to further understand the main concepts and get started.
Feedback
Are you on Discord? Connect to our channel and interact directly with the team that builds our AI services!
Esta página foi útil?
