AI Training - Job concept
Definition
A job in AI Training is the workload unit submitted to the cluster. A job runs as a Docker container within the OVHcloud infrastructure.
Each AI Training job is linked to a Public Cloud project and specifies an amount of resources to use to run the training task along with a Docker image either publicly available, in the AI Training shared registry scoped to your project or the private registry of your choosing that you added. For the latter, see the OVHcloud documentation on how to add use and manage registries.
Considerations
An AI Training job runs continuously until manually interrupted by the user or until it is done, unless it exceeds 7 consecutive days of being in a RUNNING state. It will then be automatically stopped. You can choose to automatically restart it using the auto-restart option (set this parameter to True). The job will then restart as is.
  • Data can be attached to a job to serve either/both as input for your training workload or output (e.g. model weights).
  • If you do not customize your resource request, the default requested is 1 GPU. Memory is not customizable.
  • Billing for jobs is minute-based and starts from the beginning to the end of the job's RUNNING status. Each commenced minute is billed completely.
  • You can read further on job limitations here.
Under the hood
Jobs in AI Training are Docker containers within the OVHcloud infrastructure.
Job lifecycle
During its lifetime the job will transit between the following states:
Only the RUNNING time of the job is billed. For more information about jobs billing, refer to this documentation.
  • QUEUED: The job run request is about to be processed.
  • INITIALIZING: The job instance is created and the data is synchronized from the Object Storage. To know more about the data synchronisation check out the Data How it works section.
  • PENDING: The job is being started.
  • RUNNING: The job is running.
  • INTERRUPTING: The job is still running but an interruption order was received and is about to be processed.
  • FINALIZING: The job instance is deleted and the data is synchronized back to the Object Storage. To know more about the data synchronisation check out the Data How it works section.
  • DONE: The job ended normally.
  • TIMEOUT: The job is still running but is about to be interrupted because the timeout was reached.
  • INTERRUPTED: The job is ended and was interrupted.
  • FAILED: The job ended with an error, e.g. the process in the job finished with a non 0 exit code, Docker image could not be pulled, etc.
  • ERROR: The job ended due to a backend error.
Feedback
