AI Training - Features, Capabilities and Limitations
AI Training is covered by OVHcloud Public Cloud Special Conditions.
This page provides the technical capabilities and limitations of the Public Cloud AI Training offer.
Features
Available features
AI Training allows you to train your models easily, with just a few clicks or commands. This solution runs your training job on the computational cloud resources you have chosen (CPU/GPU).
FeatureDetails
AI environments
Preinstalled Machine Learning environmentsAI Training comes with a generic Python environment (Conda) or pre-installed ones, such as Pytorch, Tensorflow, FastAI, HuggingFace and more.
Easy customizationAI Training allows installation of almost any Conda or Pip packages. You can easily customize your environment to suit your needs. It also allows you to use your own environment by specifying your Docker image.
Management
Multiple ways to manage your training jobsYou can manage your AI Training jobs through the OVHcloud Control Panel, API or CLI. Depending on your needs, you can easily automate their creation and deletion as well.
Easy start and StopYou can start and stop a training job in one click.
Check the logs of your jobYou can also check the logs of your training job through the OVHcloud Control Panel, API or CLI.
Compute resources
Guaranteed compute resourcesSelect the amount of CPUs or GPUs required during the creation of the AI Training job. Once launched, you will keep these resources as long as your job is running.
Background executionYour tasks can be executed in the background, meaning that closing your Web browser will have no effect on your work.
No maximum runtimeYour tasks can last as long as your job is running.
Monitoring toolsEach AI Training service comes with a native Grafana dashboard, allowing you to keep track and monitor your CPU, GPU, RAM and storage resources.
Storage
Fast and flexible storageEach AI Training service comes with local storage, but also the ability to attach remote storage from Object Storage. From a few GiB to multiple TiB, we push your data near our compute power on fast SSD storage for better performances.
Git repositories importationDuring the creation of your AI Training job, you can specify one or multiple Git repositories to download inside your job environment.
Security
Open or restricted authenticationDuring the creation of your AI Training job, select open or restricted access to your job. If restricted, people can be granted access via token or credentials to securely access your environment.
European valuesWe respect your privacy and will never use your personal data for our internal purposes.
Availability and billing
Easy billingYou only pay for what you consume, billed per minute.
Available in many countriesAI Training requires an OVHcloud account. We currently accept dozens of countries. Once created, you will have access to the whole set of features.
Logs and Monitoring tools
Command line interface (CLI)
AI Training is compliant with the OVHcloud AI CLI. Discover how to install the OVHcloud AI CLI.
Logs
To check the logs of your job, you can do it via the ovhai CLI using the following command:
ovhai job logs <job-id>
Monitoring tools
To see information of your job, you can do so with the ovhai CLI using the command above:
ovhai job get <job-id>
You can then access your metrics through the Monitoring Url.
You are also able to check it from the OVHcloud Control Panel in your job information by clicking the Go to Graph Dashboard button.
Planned features
We continuously improve our offers. You can follow, vote and submit ideas to add to our roadmap at https://github.com/ovh/public-cloud-roadmap/projects/4.
Capabilities and limitations
Supported regions for jobs
AI Training can be used from any country in the world, as long as you have an OVHcloud account. Physically, two datacenters are available:
  • BHS (Beauharnois, Canada, America)
  • GRA (Gravelines, France, Europe)
Attached resources
Compute resources
You can either choose the number of GPUs or CPUs for an AI Training job, not both. By default, a job uses one GPU. The memory resource is not customisable.
If you choose GPU:
  • CPU, memory and local storage resources are not customisable but scaled linearly with each additional GPU.
If you choose CPU:
  • Memory and local storage resource is not customisable but scaled linearly with each additional CPU.
The maximum amount of CPU/GPU, memory per CPU/GPU and local storage is available on the OVHcloud website, Control Panel and the ovhai CLI.
ovhai capabilities flavor list
For your information, the current limits are:
  • CPU: 12 per job.
  • GPU: 4 per job.
Available hardware for AI Training
Currently, we provide:
Available storage
Local storage
Each AI Training job comes with a local storage space, which is ephemeral. When you delete your job, this storage space is also deleted. This storage space depends on the selected instances during your AI Training job creation. Please refer to the compute resources section for more information.
Local storage is limited and not the recommended way to handle data, see the OVHcloud documentation on data for more information.
Attached storage
You can attach data volumes from Public Cloud Object Storage. The Object Storage bucket should be in the same region as your AI Training job. Attached storage allows you to work on several TB of data, while being persistent when you delete your AI Training job.
Maximum execution time
There is no duration limitation on AI Training job execution.
However, by default, your AI Training job will automatically shut down after 7 consecutive days of being in a RUNNING state. You can also enable Automatic Restart to have it restart every 7 days, or contact our support to extend this period to 28 days.
Pre-installed AI environments
OVHcloud AI Training comes with pre-installed AI environments.
List of available AI Environments:
  • AutoGluon + MXNet
  • FastAI
  • HuggingFace
  • Miniconda (Python generic)
  • MXNet
  • One image to rule them all
  • PyTorch
  • Scikit-Learn
  • TensorFlow
Environment customization
Each environment can be customized directly with PIP or CONDA (we support almost any package and library).
You can also use your own Docker images.
Docker images can be hosted in a public or private registry.
The use of docker-compose is not possible.
Please be aware that images need to be built with an AMD architecture.
Learn how to build and use your custom Docker image in this tutorial.
Network
  • Public networking can be used for all the AI Tools.
  • Private networking (OVHcloud vRack) is not supported.
Available ports to public network
Each AI Training job exposes a public URL that defaults to port 8080. This default port can be configured when you submit a new job. This URL is mapped to only one port, but you can access other ports than the default one by appending the port number to your job URL.
For example, if you want to access port 9000 from your job, you will have to add -9000 to your job URL. Your job URL for accessing the 9000 port will then be https://00000000-0000-0000-0000-000000000000-9000.job.gra.ai.cloud.ovh.net/
Quotas per Public Cloud project
Each Public Cloud project grants a customer by default a maximum of 4 GPUs used simultaneously. Reach out to our support if you need to increase this limitation.
Browse the full AI Training documentation to further understand the main concepts and get started.
Feedback
Are you on Discord? Connect to our channel and interact directly with the team that builds our AI services!
Czy ta strona była pomocna?
