Responsibility sharing - Domain Name service (EN)
The RACI below details shared responsibilities between OVHcloud and the customer for the Domain Name service. This shared model can help relieve the customer’s operational burden.
Roles
R: Is in charge of carrying out the process
A: Is Accountable for the successful completion of the process
C: Is consulted during the process
I: Is informed of the results of the process
1. Before subscription
1.1. Specify service as needed
ActivityCustomerOVHcloud
Choose the name of the serviceRA
Define the list of TLD you want to cover with the nameRA
Define the close domain names you want to protect against malicious usesRA
2. Service availability
2.1. Install service
Check the availability of the domains you wantRA
Register the mark of your service if neededRA
Register the domainIRA
Generate the customer interface to manage its DNS zoneIRA
2.2. Reversibility model
Domain Names are fully reversible by design. DNS Zones may be backuped in txt files and deployed on any new DNS server.
Know the services that depend on some DNS registeringsRA
2.3. Customer Information System setup
Deploy the configuration on the DNS zone in full autonomyRA
Deploy the configuration on the DNS zone with the help of OVHcloud automatization toolsRIAI
3. Service usage
3.1. Operations
3.1.1. Daily operations
Perform the DNS modifications for services deployed in full autonomyRA
Perform the DNS modifications for services deployed via OVHcloud automatization toolsRIRA
3.1.2. Access management
Manage access to the DNS zone configuration toolRAI
3.1.3. Monitoring
Monitor the DNS serversRA
Monitor the DNS zone entriesA
3.1.4. Storage
Store the DNS zoneRA
3.1.5. Connectivity
Manage the availability of the DNS serviceRA
3.1.6. Management
Manage domain and sub-domainsRA
3.1.7. Business continuity
Manage business continuity of OVHcloud DNS serversRA
Install or subscribe secondary DNS services (not useful excepting highly specific cases)RA
3.2. Event management
3.2.1. Incidents
Restore the DNS serviceRA
Restore the DNS entriesRA
3.2.2. Changes
Give the contacts data required by DNS registeringRAI
Update the contacts data in the registry in accordance with local regulations / GDPRRA
4. Reversibility
4.1. Reversibility model
Document the services that depend on some DNS registeringsRA
Plan the DNS zone migration in accordance with the security requirements of DNS dependant servicesRA
4.2. Data recovery
Copy the DNS zone configurationRA
5. End of service
5.1. Destroying configurations
Remove the DNS zone from OVHcloud DNS serversIRA
5.2. Data destruction
Remove the customers recordings from OVHcloud systems when recording deadlines are exceededRA
War diese Seite hilfreich?
