title: "Configure incoming connections of a Public Cloud Databases for Valkey service"
description: "Find out how to configure your Valkey service to accept incoming connections"
url: https://docs.ovhcloud.com/pl/guides/public-cloud/databases/valkey-prepare-for-incoming-connections
lang: pl
lastUpdated: 2024-06-12
> For AI agents: the complete documentation index is available at https://docs.ovhcloud.com/pl/llms.txt, the full documentation bundle is available at https://docs.ovhcloud.com/pl/llms-full.txt.
# Configure incoming connections of a Public Cloud Databases for Valkey service
## Objective
Public Cloud Databases allow you to focus on building and deploying cloud applications while OVHcloud takes care of the database infrastructure and maintenance in operational conditions.
**This guide explains how to configure your Valkey instance to accept incoming connections.**
## Requirements
- A [Public Cloud project](https://www.ovhcloud.com/pl/public-cloud/) in your OVHcloud account
- A Valkey service running on your OVHcloud Public Cloud Databases ([this guide](https://docs.ovhcloud.com/pl/guides/public-cloud/databases/getting-started.md) can help you to meet this requirement)
### OVHcloud Control Panel Access
- **Direct link:** <ManagerLink to="/#/public-cloud/pci/projects">All my Public Cloud projects</ManagerLink>
- **Navigation path:** <code className="action">Public Cloud</code> > Select your project > <code className="action">Databases</code>
## Instructions
### Configure your Valkey instance to accept incoming connections
Before making a connection, we need to verify that our Valkey instance is correctly configured.
Click on `Databases
` in the left-hand navigation bar and select your Valkey instance.
#### Step 1: Verify your user roles and password
Select the `Users
` tab. Verify that you have a user with sufficient rights and a password. If you don't remember the user's password, you can either create a new user or regenerate the password of an existing user. Be careful! By doing so you will need to update all the places where you already use this user/password pair.
In our example, we will create a user called _redisUser_ and rights for :
- Keys:
  - **\*** (for _allkeys_)
- Commands:
  - **+ping** (for the _ping_ command)
  - **+info** (for the _info_ command)
  - **+echo** (for the _echo_ command)
  - **+get** (for the _get_ command)
  - **+set** (for the _set_ command)
  - **+client** (for the _client_ command)
- Channels:
  - **\*** (for _allchannels_)
![User creation](/images/public-cloud/databases/redis-08-prepare-for-incoming-connections/redis_08_prepare_for_incoming_connections-2022032912263856.png)
Once created or updated, the user has to be ready and with the "Enabled" status in the Control Panel.
![User ready](/images/public-cloud/databases/redis-08-prepare-for-incoming-connections/redis_08_prepare_for_incoming_connections-20220329122758377.png)
:::info
Follow the [Commands Official Documentation](https://redis.io/commands/) to learn more.
Follow this [guide](https://docs.ovhcloud.com/pl/guides/public-cloud/databases/valkey-capabilities.md#users-and-roles) to learn more about users and roles capabilities and limitations.
#### Step 2: Authorise incoming connections from the service
:::warning
For security reasons the default network configuration doesn't allow any incoming connections. It is thus critical you authorise the suitable IP addresses in order to successfully access your database.
In this step, select the `Authorised IPs
` tab. IP addresses must be authorised here before they can connect to your database.
Clicking on `Add an IP address or IP address block (CIDR)
` opens a new window in which you can add single IP addresses or blocks to allow access to the database.
![Add an IP](/images/public-cloud/databases/redis-08-prepare-for-incoming-connections/ip_authorize.png)
You can edit and retract database access via the `...
` button in the IP table.
:::info
If you want to allow connections from the outside, you can enter the IP 0.0.0.0/0. Please use it carefully.
#### Collect required information
Select the `General information
` tab to find the required login credentials in the `Login informations`
 section.
![Login informations](/images/public-cloud/databases/redis-08-prepare-for-incoming-connections/redis_08_prepare_for_incoming_connections-20220329100705698.png)
## Go further
Visit the [Github examples repository](https://github.com/ovh/public-cloud-databases-examples/tree/main/databases/redis) to find how to connect to your database with several languages.
Visit our dedicated Discord channel: [https://discord.gg/ovhcloud](https://discord.gg/ovhcloud). Ask questions, provide feedback and interact directly with the team that builds our databases services.
For training or technical assistance implementing our solutions, contact your sales representative or visit our [Professional Services](https://www.ovhcloud.com/pl/professional-services/) page to request a quote and have your project analysed by our experts.
