title: "Mutualized input - OpenSearch API"
description: "Send your logs to the platform with the OpenSearch API."
url: https://docs.ovhcloud.com/pl/guides/manage-and-operate/observability/logs-data-platform/ldp-index
lang: pl
lastUpdated: 2025-10-16
# Mutualized input - OpenSearch API
## Overview
OpenSearch is the star component of our platform, making it possible to use [OpenSearch indexes](/pl/guides/manage-and-operate/observability/logs-data-platform/index-as-a-service.md) to store your documents. The OpenSearch indexes are quite flexible, but they are not part of the log pipeline. If you want to also use the [Websocket live-tail](/pl/guides/manage-and-operate/observability/logs-data-platform/ldp-tail.md), or the [Alerting system](/pl/guides/manage-and-operate/observability/logs-data-platform/alerting.md) or the [Cold Storage](/pl/guides/manage-and-operate/observability/logs-data-platform/archive-cold-storage.md) feature, and have automatic retention management, then you will need to use the log pipeline. Thanks to our OpenSearch log endpoint, it shall enable you to send logs using the HTTP OpenSearch API. Moreover, the endpoint supports also [OpenSearch Ingest](https://opensearch.org/docs/latest/opensearch/rest-api/ingest-apis/index/), meaning you can use advanced processing on your logs before they are sent in the pipeline. There is no additional cost for this feature, all you need is a [stream](/pl/guides/manage-and-operate/observability/logs-data-platform/getting-started-quick-start.md).
## OpenSearch endpoint
The OpenSearch endpoint is a dedicated index where you can send a JSON document. The port used is the **9200**, the same HTTP port used for all other OpenSearch APIs of Logs Data Platform. The request must include the **X‑OVH‑TOKEN** field, which is a token used by the logging pipeline, and any additional custom fields. Authentication for the endpoint is performed via basic username/password (or a legacy token) for non‑IAM users, or via an IAM **Bearer** token when IAM is enabled. Don't hesitate to go to the [Quick Start documentation](/pl/guides/manage-and-operate/observability/logs-data-platform/getting-started-quick-start.md) if you are not familiar with this notion. This document log will be transformed into a valid GELF log and any missing field will be filled automatically. In order to respect the GELF convention, you can also use all the [GELF format reserved fields](https://docs.graylog.org/docs/gelf). Here is one example of the minimal message you can send:
```bash
$ curl -H 'Content-Type: application/json' -u '<user>:<password>' -XPOST https://<ldp-cluster>.logs.ovh.com:9200/ldp-logs/_doc -d '{ "X-OVH-TOKEN" : "7f00cc33-1a7a-4464-830f-91be90dcc880" , "test_field" : "OVHcloud"}'
or with [IAM enabled](/pl/guides/manage-and-operate/observability/logs-data-platform/iam-presentation-faq.md)
```bash
$ curl -H 'Content-Type: application/json' --oauth2-bearer '<YOUR_IAM_TOKEN>' -XPOST https://<ldp-cluster>.logs.ovh.com:9200/ldp-logs/_doc -d '{ "X-OVH-TOKEN" : "7f00cc33-1a7a-4464-830f-91be90dcc880" , "test_field" : "OVHcloud"}'
Replace the `<user>`, `<password>` and `<ldp-cluster>` with your Logs Data Platform username, password and cluster. You can also use [tokens](/pl/guides/manage-and-operate/observability/logs-data-platform/tokens.md) in place of your credentials.  Sending this payload will result in this log:
![simple\_log](/images/manage-and-operate/observability/logs-data-platform/ingestion-opensearch-api-mutualized-input/one_field.png)
The system automatically set the timestamp at the date when the log was received and added the field **test\_field** to the log message. Source was set to **unknown** and the message to `-`.
Note that the payload follows the JSON specification (and not the GELF one). The system will still recognize any reserved field used by the [GELF specification](https://docs.graylog.org/docs/gelf). Here is another example:
```bash
$ curl -H 'Content-Type: application/json' -u '`<user>`:<password>' -XPOST https://`<ldp-cluster>`.logs.ovh.com:9200/ldp-logs/_doc -d '{ "X-OVH-TOKEN" : "7f00cc33-1a7a-4464-830f-91be90dcc880" , "test_field" : "OVHcloud" , "short_message" : "Hello OS input", "host" : "OVHcloud_doc" }'
This will create the following log:
![gelf\_log](/images/manage-and-operate/observability/logs-data-platform/ingestion-opensearch-api-mutualized-input/gelf_log.png)
The system used the reserved fields associated with GELF to create the message and the source fields.
Logs Data Platform will also detect any typed field in the original data and convert them accordingly to our [field naming convention](/pl/guides/manage-and-operate/observability/logs-data-platform/field-naming-conventions.md). This last example illustrates it:
```bash
$ curl -H 'Content-Type: application/json' -u '`<user>`:<password>' -XPOST https://`<ldp-cluster>`.logs.ovh.com:9200/ldp-logs/_doc -d '{ "X-OVH-TOKEN" : "7f00cc33-1a7a-4464-830f-91be90dcc880" , "test_field" : "OVHcloud" , "short_message" : "Hello OS input", "host" : "OVHcloud_doc", "numeric_field" : 43.5  }'
The numeric field **numeric\_field** will be detected as a number and will be suffixed to follow our naming conventions.
![gelf\_convention](/images/manage-and-operate/observability/logs-data-platform/ingestion-opensearch-api-mutualized-input/gelf_convention.png)
The OpenSearch input will also flatten any sub-object or array sent through it and also supports ingest pipelines that are used, for example, with [Filebeat integrations](/pl/guides/manage-and-operate/observability/logs-data-platform/filebeat-logs.md).
### Using the OpenSearch API with IAM enabled
When **IAM** is enabled for your Logs Data Platform service, the authentication method for the OpenSearch API changes:
- **Legacy (non‑IAM) authentication** uses basic username/password (or a legacy token) as described in the existing examples.
- **IAM authentication** uses a **Bearer token** obtained from OVHcloud IAM (Personal Access Token or Service Account token).
**How to obtain a Bearer token** – you can generate one via a service account or a local user:
For a service account:
- Create a service account and assign the required IAM policies (see the [IAM access management guide](/pl/guides/manage-and-operate/observability/logs-data-platform/iam-access-management.md)).
- Retrieve an API token using the OAuth2 client‑credentials flow as described in the [service‑account authentication guide](/pl/guides/account-and-service-management/account-information/authenticate-api-with-service-account.md). The request looks like:
  ```bash
  curl --request POST \
       --url 'https://www.ovh.com/auth/oauth2/token' \
       --header 'content-type: application/x-www-form-urlencoded' \
       --data grant_type=client_credentials \
       --data client_id=<service_account_id \
       --data client_secret=`<service_account_secret>` \
       --data scope=all
  The response contains an `access_token` field – this is the Bearer token to use.
For a local user:
- You can create a local user by following the dedicated section on the Identities management guide.
- You can generate a Personal Access Token via the IAM API. See the FAQ documentation or use the call:
🇪🇺EU▾
[POST/me/identity/user/{user}/token](https://eu.api.ovh.com/console/?section=/me&branch=v1#post-/me/identity/user/-user-/token)
Replace `{user}` with your OVHcloud local user. The response also returns an `access_token` that can be used as a Bearer token.
#### New request format
```bash
# Ingest a log with IAM (Bearer token in header)
curl -H 'Content-Type: application/json' \
     -H 'Authorization: Bearer <YOUR_IAM_TOKEN>' \
     -XPOST https://<ldp-cluster>.logs.ovh.com:9200/ldp-logs/_doc \
     -d '{ "test_field" : "OVHcloud", "short_message" : "Hello with IAM" }'
_Notes_:
- The **index/alias prefix** is now the **service name** (e.g. `ldp-ab-56945`) instead of the username. You can find the service name on the Logs Data Platform home page or in the service URN (`urn:v1:eu:resource:ldp:<service-name>`).
- The same Bearer token can be used for **querying** the OpenSearch backend:
```bash
# Ingest a log with IAM (dedicated option in recents version of curl)
curl -k -v -H 'content-type: application/json' \
     --oauth2-bearer `<YOUR_IAM_TOKEN>` \
     -XGET 'https://gra1.logs.ovh.com:9200/_cluster/health?pretty'
#### Hybrid authentication (Bearer token with Basic scheme)
For clients that do not support the `Authorization: Bearer` header, you can use the Bearer token value with a Basic authentication scheme by prefixing it by `pat_jwt_` as follows:
```bash
Authorization: Basic pat_jwt_<your_value>:<bearer_token_value>
Replace `<your_value>` with any ASCII value to identify your Personal Access Token (PAT) and `<bearer_token_value>` with the token obtained as described above. This allows the request to be accepted by the OpenSearch endpoint with a user/password couple while using the same token.
All existing examples that use basic credentials remain valid for customers who have **not** enabled IAM.
## Use case: Vector
[Vector](https://vector.dev/) is a fast and lightweight log forwarder written in Rust. This software is quite similar to [Logstash](/pl/guides/manage-and-operate/observability/logs-data-platform/logstash-input.md) or [Fluent Bit](/pl/guides/manage-and-operate/observability/logs-data-platform/kubernetes-fluent-bit.md). It takes logs from a source, transforms them and sends them in a format compatible with the configured output module.
The vector integrations are numerous with more than 20 sources supported, more than 25 transforms and 30 sinks supported. It supports OpenSearch as a sink thanks to its Elasticsearch compatibility. We will use the simplest configuration to make it work from a **journald** source to our OpenSearch endpoint. Don't hesitate to check the [documentation](https://vector.dev/docs/about/what-is-vector/) to explore all the possibilities.
```toml
data_dir = "/var/lib/vector" # optional, must be allowed in read-write
[sources.journald]
type = "journald" # required
[transforms.token]
#This VRL transorm add the token
type = "remap"
inputs = ["journald"]
source = '''
."X-OVH-TOKEN" = "`<stream-token>`"
[sinks.ldp]
type = "elasticsearch" # required
inputs = ["token"] # required
mode = "bulk"
api_version = "v7"
compression = "gzip" # optional, default is none
healthcheck = true # required
endpoint = "https://<`<ldp-cluster>`>.logs.ovh.com:9200" # required
bulk.index = "ldp-logs" # required
auth.strategy = "basic"
auth.user = "`<username>`"
auth.password = "`<password>`"
Here is the explanation of this configuration.
The source part of the TOML configuration file configure the [journald](https://vector.dev/docs/reference/configuration/sources/journald/) source. By default this source will use the `/var/lib/vector` directory to store its data. You can configure this directory with the global option data\_dir.
The transform configuration part relates to the [remap](https://vector.dev/docs/reference/configuration/transforms/remap/)
 transform. This transform named here token has for unique goal to add the token stream value. It takes logs from the **inputs**
 named journald and adds a **X-OVH-TOKEN**
 value. This token value can be found on the `...
` stream menu on the stream page in the Logs Data Platform manager. Replace **`<stream-token>`**
 with the token value of your stream.
The final part is the [Elasticsearch sink](https://vector.dev/docs/reference/configuration/sinks/elasticsearch/). It takes data from the previous **inputs** token and sets up several config points:
- gzip is supported on our endpoint, so it's activated with the **compression** configuration.
- **healthcheck** is also supported and allows you to be sure that the platform is alive and well
- the **endpoint** configuration must be replaced with your assigned cluster
- the **bulk.index** must be set to "ldp-logs", our special OpenSearch logs index
- the **auth.strategy** must be set to "basic".
- **auth.user** and **auth.password** must be set to the username of the Logs Data Platform account and its associated password. Note that you can use [tokens](/pl/guides/manage-and-operate/observability/logs-data-platform/tokens.md) in place of your credentials.
Once configured and launched you will immediately see this type of logs in Graylog:
![vector\_logs](/images/manage-and-operate/observability/logs-data-platform/ingestion-opensearch-api-mutualized-input/vector_logs.png)
The logs from journald arrived fully parsed and ready to be explored. Use different sources and transforms to send your application logs to Logs Data Platform.
## Go further
- Getting Started: [Quick Start](/pl/guides/manage-and-operate/observability/logs-data-platform/getting-started-quick-start.md)
- Documentation: Guides
- Community hub: [community of users](https://community.ovhcloud.com/)
- Create an account: [Try it!](https://www.ovh.com/fr/order/express/#/express/review?products=~\(~\(planCode~'logs-account~productId~'logs\)\))
