title: "'Order OVHcloud Connect Direct'"
description: "'Find out how to order a direct physical connection to OVHcloud through the Control Panel or the API'"
url: https://docs.ovhcloud.com/es/guides/network/ovhcloud-connect/order-direct
lang: es
lastUpdated: 2026-06-16
# Order OVHcloud Connect Direct
## Objective
This guide explains how to order a **direct physical connection** to OVHcloud through the OVHcloud Control Panel or the API.
## What you will need
Before starting the order, prepare the following:
| Information                    | Description        |
| **PoP location**               | The data centre where you want to connect (see [PoP Locations](/es/guides/network/ovhcloud-connect/pop-locations-regions.md)) |
| **Bandwidth**                  | The speed of the connection (e.g. 1, 10 or 100 Gbps)        |
| **Your ASN**                   | Your Autonomous System Number (public or private) for BGP peering                                                             |
| **IP plan**                    | The prefixes you intend to advertise and the peering subnet        |
| **Contact details**            | Technical and billing contacts for the order        |
| **Cross-connect instructions** | Cage/cabinet references if you have your own space in the data centre                                                         |
Log in to your OVHcloud Control Panel
 and go to `Network
` > `OVHcloud Connect
## Order via the OVHcloud Control Panel
1. Click <code className="action">Order</code>.
2. Select <code className="action">OVHcloud Connect Direct</code>.
3. Choose your **PoP location** from the list of available sites.
4. Select the desired **bandwidth** (1, 10 or 100 Gbps).
5. Fill in the **technical details**:
   - Your ASN
   - Preferred VLAN ID (if applicable)
   - Contact information for LOA delivery
   - Any special instructions for the data centre cross-connect
6. Review the **pricing and contract terms** (minimum commitment period, monthly fee).
7. <code className="action">Confirm</code> the order.
You will receive an email confirmation with your order reference and estimated delivery timeline.
## Order via the API
You can also order programmatically using the [OVHcloud API](https://eu.api.ovh.com/console/?section=%2FovhCloudConnect\&branch=v1).
```python
import ovh
client = ovh.Client(endpoint='ovh-eu')
# Example: list your existing OVHcloud Connect services
# Check the API console for the exact endpoint and parameters
result = client.get('/ovhCloudConnect')
print(result)
Refer to the [Automation guide](/es/guides/network/ovhcloud-connect/automation.md) for API setup instructions.
## What happens after ordering
![What happens after ordering](/images/network/ovhcloud-connect/order-direct/fig-1.svg)
1. **Order confirmed** — You receive an email with your order reference.
2. **LOA delivered** — OVHcloud issues the Letter of Authorization **within minutes** of the order. The LOA contains the data centre details needed to install the cross-connect.
3. **Cross-connect installed** — Give the LOA to your data centre operator. They install the fibre patch cable. Timing depends on the facility (a few days to 2 weeks).
4. **Port becomes active** — Once the cross-connect is in place and OVHcloud detects light, the port becomes active and the service is delivered. You can now configure BGP and associate with your vRack.
:::warning
After the order, you have **60 days** to finalize the interconnection (order the cross-connect and connect your equipment). Beyond 60 days — even without detected light — the service is considered operational and **billing starts**.
## Pricing and billing
- OVHcloud Connect Direct is billed **monthly**.
- Pricing depends on the PoP location and bandwidth tier.
- A **minimum commitment period** may apply (check during ordering).
- Cross-connect fees from the data centre operator are separate and billed by the operator.
## What's next?
- [Receive and use your LOA](/es/guides/network/ovhcloud-connect/cross-connect-loa.md)
- [Configure OCC L3 with BGP](/es/guides/network/ovhcloud-connect/l3-bgp.md)
- [Associate with your vRack](/es/guides/network/ovhcloud-connect/associate-vrack.md)
## Go further
For training or technical assistance implementing our solutions, contact your sales representative or visit our [Professional Services](https://www.ovhcloud.com/es-es/professional-services/) page to request a quote and have your project analyzed by our experts.
