title: "Tracking connections on the OVHcloud Load Balancer"
url: https://docs.ovhcloud.com/es/guides/network/load-balancer/create-stickiness
lang: es
lastUpdated: 2025-11-27
# Tracking connections on the OVHcloud Load Balancer
## Objective
The [OVHcloud Load Balancer](https://www.ovhcloud.com/es-es/network/load-balancer/) service offers several methods for **tracking connections** (also known as _session persistence_ or _stickiness_) to your services.
Each session on the OVHcloud Load Balancer service is maintained by a persistent connection system. This system is configured at the **application layer** of the OVHcloud Load Balancer service to ensure persistent connections to the server.
**This guide provides different methods to configure connection tracking for the OVHcloud Load Balancer.**
## Requirements
- An [OVHcloud Load Balancer](https://www.ovhcloud.com/es-es/network/load-balancer/)
- Access to the <ManagerLink to="/">OVHcloud Control Panel</ManagerLink>, or
- Access to the [OVHcloud API](https://eu.api.ovh.com/)
## Instructions
### The different types of connection tracking
There are two primary connection tracking methods that can be configured for your services:
| Tracking method | Details        |
| Cookie          | Configures a session cookie, which is used to distribute traffic from a single HTTP session to the same server in the farm.                                                            |
| SourceIp        | A hash algorithm is applied to the source IP address of the request received by the OVHcloud Load Balancer. This ensures the same client IP is consistently routed to the same server. |
The following elements will affect traffic redirection:
- if the configured server weight changes
- if a server in the farm is re-enabled
- if a server in the farm is no longer responding
:::warning
Once you have applied your configuration, existing connections will be rebalanced, and their associated HTTP sessions will be lost.
### Modify a server farm's connection tracking method via the OVHcloud Control Panel
To modify connection tracking for a server farm, navigate to the `Server clusters` tab, then click the options button `...` to the right of the desired farm and select `Edit`:
![Modify a farm](/images/guides/network/load-balancer/create-stickiness/farm_edit-2022.png)
In the `Advanced settings` section, you will be able to access the `Track session` section:
![Modifying connection tracking](/images/guides/network/load-balancer/create-stickiness/tracking_session-2022.png)
Once you have configured the farm, click `Add` or `Edit`, depending on whether you are configuring a new or modifying an existing farm.
Please remember to deploy the configuration afterward. There are two ways to do so:
- via the `Status` section of the Control Panel, by clicking on your Load Balancer's `...` button, then selecting `Apply configuration`
- via the reminder box in the Control Panel, notifying you that the configuration has not been applied, by clicking `Apply configuration`
![Apply a Load Balancer configuration](/images/guides/network/load-balancer/create-stickiness/apply_configuration-2022.png)
### Modify a server farm's connection tracking method via the API
#### View details on a server farm
This API call allows you to view details for a server farm if you know its ID. For this example, we will work on an HTTP farm.
🇪🇺EU▾
[GET/ipLoadbalancing/{serviceName}/http/farm/{farmId}](https://eu.api.ovh.com/console/?section=/ipLoadbalancing&branch=v1#get-/ipLoadbalancing/-serviceName-/http/farm/-farmId-)
| Setting       | Meaning                              |
| serviceName\* | The ID of your Load Balancer service |
| farmId\*      | The ID number of the farm            |
| Response (BackendHttp) | Meaning                                                         |
| farmId                 | The ID number of the farm                                       |
| balance                | Load balancing algorithm currently enabled for the farm         |
| zone                   | Name of the zone in which the farm is configured                |
| port                   | Port used to contact the backend servers configured on the farm |
| probe                  | Type of health probe currently configured on the farm           |
| displayName            | User-friendly name given to this farm                           |
| stickiness             | Connection tracking method currently set for the farm           |
#### Modify a server farm's connection tracking method
This API call allows you to edit the settings of a server farm if you know its ID. In this example, we will work on an HTTP farm. To modify the tracking method, the `BackendHttp.stickiness` field must be updated with an available connection tracking method:
🇪🇺EU▾
[PUT/ipLoadbalancing/{serviceName}/http/farm/{id}](https://eu.api.ovh.com/console/?section=/ipLoadbalancing&branch=v1#put-/ipLoadbalancing/-serviceName-/http/farm/-id-)
| Setting                | Meaning                                            |
| BackendHttp.stickiness | The connection tracking method chosen for the farm |
#### Apply the modifications
This API call is required to deploy the configuration changes to the Load Balancer service.
🇪🇺EU▾
[POST/ipLoadbalancing/{serviceName}/refresh](https://eu.api.ovh.com/console/?section=/ipLoadbalancing&branch=v1#post-/ipLoadbalancing/-serviceName-/refresh)
| Setting       | Meaning        |
| zone          | Name of the zone in which to deploy the configuration (e.g. "all" or "rbx") |
## Go further
